[postgis-users] Problems finding PostgresQL on an FC4 installation
Putler, Dan Dan.Putler at sauder.ubc.ca
Fri Jan 6 15:13:13 PST 2006
Hi All,
I'm having a heck of a time installing PostGIS 1.1.0 on an FC4 system
(with a P3 processor) that is running Postgresql 8.1.1, GEOS 2.2.1,
and Proj 4.4.9.
I installed Postgresql from source with /usr/local/pgsql as the
installation directory. As a result, I configured PostGIS using the
option --with-pgsql=/usr/local/pgsql (I've also tried /usr/local and /
usr/local/pgsql/bin as the postgres directories). Things seem to go
along fine with configure since it finds geos, and proj, and doesn't
complain about postgres. However, when I become root and attempt
make, bad things happen. I created a transcript of the session, and
here are the first few lines of the output of the make process, which
might provide a clue to my problem:
make -C lwgeom
make[1]: execvp: /usr/local/pgsql: Permission denied
make[1]: Entering directory `/home/putler/build/postgresql-8.1.1/
contrib/postgis-1.1.0/lwgeom'
gcc -DUSE_VERSION=82 -DPOSTGIS_LIB_VERSION='"1.1.0"' -
DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"' -
DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-06
22:23:57"' -I/usr/local/include -DUSE_PROJ  -I -DAUTOCACHE_BBOX=1  -
DUSE_STATS -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/
include     -c -o liblwgeom.o liblwgeom.c
In file included from liblwgeom.c:26:
lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
lwgeom_pg.h:28: error: syntax error before â
The three header files make can't find are part of postgres, so my
guess is make still can't find postgres. I've played with
LD_LIBRARY_PATH without any luck (which isn't surprising since it
doesn't point to the header directories). Any ideas about what I'm
not doing to make postgres visible?
Dan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060106/f0079a06/attachment.html>
