[postgis-users] Can PostGIS do Route optimization / shortest pass
alex bodnaru
alexbodn at 012.net.il
Mon Jan 9 17:32:50 PST 2006
hi,
while that would be my first try at postgresql internals, i would like
to help.
alex
Daniel wrote:
> We choose to use recent postgis to implement these feature, but a
> backport to older versions was considered: it is possible by modifying
> the C source code (a good c++ skill is required)
> dF
> Chris Matheson wrote:
>> Frank Warmerdam wrote:
>>> On 1/6/06, Fdu (sent by Nabble.com) <lists at nabble.com> wrote:
>>>> Is there route optimization functionality in PostGIS? Given starting
>>>> point
>>>> and end point (assume there is street center line in database), does
>>>> PostGIS
>>>> have any existing function which can calculate shortest route (in
>>>> time or
>>>> distance)? If it does, what kind of information I can get from it?
>>>> Such as
>>>> total route time, route length, and route description, points/polylines
>>>> which make the route?
>>> Fay,
>>> I'm sure others know lots more about this than me, but
>>> you can find a routing module at:
>>> http://www.cartoweb.org/contribs.html
>>> Best regards,
>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>> warmerdam at pobox.com
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Does anyone know of something similar for versions of PostgreSQL
>> before 8.0 (specifically 7.4.8)?
>> Chris M.
