[postgis-users] SQL Statement for Multiple Tables - operator doesn't exist: boolean && geometry
Paul Ramsey pramsey at refractions.net
Wed Jan 11 22:50:27 PST 2006
Just add an "and":
SELECT zipcodes.name, urban_areas.name, states.state
FROM zipcodes, urban_areas, states
WHERE distance( zipcodes.the_geom, 'POINT(-88.0501 41.8623)') = 0 AND
zipcodes.the_geom && urban_areas.the_geom
AND zipcodes.the_geom && states.the_geom
On Jan 11, 2006, at 10:39 PM, Adam wrote:
> I have three tables:  zip codes, metro areas, and states.
> My sql statement is:
> SELECT zipcodes.name, urban_areas.name, states.state FROM zipcodes,
> urban_areas, states WHERE distance( zipcodes.the_geom, 'POINT
> (-88.0501 41.8623)') = 0 AND zipcodes.the_geom &&
> urban_areas.the_geom && states.the_geom
> When I try to query them all in one statement I get this error:
> operator does not exist, boolean && geometry
> Hint:  No operator matches the given name and argument type(s).
> You may need to add explicit type casts.
> If I run this statement with only two tables instead of three this
> statement will work.
> How should I join three plus tables and query for one locaton?
> postgis-users mailing list
