[postgis-users] SQL Statement for Multiple Tables - operatordoesn't exist: boolean && geometry
TECHER David davidtecher at yahoo.fr
Wed Jan 11 23:56:06 PST 2006
Hi Adam
That's not really the best solution but you can try this for this moment:
Add "distinct" after "select" and test with "and counties.county is not
null"
SELECT disticnt zipcodes.name, urban_areas.name, states.state,
time_zones.gmt_offset, counties.county
FROM zipcodes, urban_areas, states, time_zones, counties
WHERE zipcodes.the_geom && urban_areas.the_geom AND
             zipcodes.the_geom && states.the_geom AND
             zipcodes.the_geom && time_zones.the_geom AND
             zipcodes.the_geom && counties.the_geom
AND distance( zipcodes.the_geom, 'POINT(-88.050121 41.862380)') = 0
and counties.county is not null
Adam a écrit :
> I changed my query to this:
> SELECT zipcodes.name, urban_areas.name, states.state,
> When it runs I get multiple rows with states and counties way off
> point.  \
> The output should look like:  60137, Chicago Metro Area, Illinois, -6,
> DuPage County
> But here's my output:
> 60137, Chicago Metro Area, Michigan, -6,
> 60137, Chicago Metro Area, Michigan, -6, Cook County
> 60137, Chicago Metro Area, Michigan, -6, DuPage County
> 60137, Chicago Metro Area, Illinois, -6, Cook County
> 60137, Chicago Metro Area, Illinois, -6, DuPage County
> 60137, Chicago Metro Area, Michigan, -5,
> 60137, Chicago Metro Area, Michigan, -5, Cook County
> 60137, Chicago Metro Area, Michigan, -5, DuPage County
> 60137, Chicago Metro Area, Illinois, -5,
> 60137, Chicago Metro Area, Illinois, -5, Cook County
> 60137, Chicago Metro Area, Illinois, -5, DuPage County
> What am I doing wrong with this query?
> ----- Original Message ----- From: "Paul Ramsey"
> <pramsey at refractions.net>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, January 12, 2006 12:50 AM
> Subject: Re: [postgis-users] SQL Statement for Multiple Tables -
>> Just add an "and":
>> WHERE distance( zipcodes.the_geom, 'POINT(-88.0501 41.8623)') = 0 AND
>> AND zipcodes.the_geom && states.the_geom
>> On Jan 11, 2006, at 10:39 PM, Adam wrote:
>>> I have three tables:  zip codes, metro areas, and states.
>>> My sql statement is:
>>> SELECT zipcodes.name, urban_areas.name, states.state FROM zipcodes,
>>> urban_areas, states WHERE distance( zipcodes.the_geom, 'POINT
>>> (-88.0501 41.8623)') = 0 AND zipcodes.the_geom &&
>>> urban_areas.the_geom && states.the_geom
>>> When I try to query them all in one statement I get this error:
>>> operator does not exist, boolean && geometry
>>> Hint:  No operator matches the given name and argument type(s).
>>> You may need to add explicit type casts.
>>> If I run this statement with only two tables instead of three this
>>> statement will work.
>>> How should I join three plus tables and query for one locaton?
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
