[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jan 14 20:30:04 PST 2006
Hi Alex,
I am running a debian sarge amd64 system and have grabbed the sid source
for postgresql and build it. Is there a package for postGIS-1.1.0 that I
can download and build for dpkg?
It looks like I might be able to follow the pocedure your listed below.
Is this correct? I have the patch file you posted before.
Thanks,
   -Steve
alex bodnaru wrote:
> assad,
> your ./configure output seems a little wird for a clean postgresql sarge
> installation.
> the procedure below will possibly help. if still in problem, you might
> need to have a better backported postgresql for sarge, or upgrade debian.
> please apply this diff to the *clean* postgis source:
> cd postgis_source_root
> zcat the_attached_file | patch -p1
> # you should have ./debian subdirectory in postgis_source_root
> chmod ug+x debian/rules
> dpkg-buildpackage -rfakeroot
> good luck,
> alex
> Assad Jarrahian wrote:
>>Alex,
>>  I am running sarge. How do I get a hold of that package.
>>I looked at http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl/PackageList
>>and it says postgis (now uninstallable)
>>thanks for your help alex.
>>-assad
>>On 1/13/06, alex bodnaru <alexbodn at 012.net.il> wrote:
>>>what debian version do you have?
>>>>I took a closer look. The directory /usr/include/postgresql/ exists
>>>>and postgres.h is in that directory.
>>>>There is no 8.1 directory.
>>>>How do I mend the problem (tell pg-config that the directory is somewhere else)
>>>>much thanks and sorry for the initial lookover of the file existing.
>>>>-assad
>>>>On 1/13/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>This is your problem:
>>>>>gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.0"'
>>>>>-DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
>>>>>-DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-12
>>>>>16:30:40"' -I/usr/local/include -DUSE_PROJ
>>>>>-I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1  -DUSE_STATS
>>>>>-Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include     -c
>>>>>-o liblwgeom.o liblwgeom.c
>>>>>In file included from liblwgeom.c:26:
>>>>>lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
>>>>>Do you stil confirm that this file exist:
>>>>>      /usr/include/postgresql/8.1/server/postgres.h
>>>>>--strk;
>>>>>On Fri, Jan 13, 2006 at 01:15:45AM -0700, Assad Jarrahian wrote:
>>>>>>strk, stefano, david .... please help. Am stuck.
>>>>>>Thanks.
>>>>>>-assad
>>>>>>On 1/12/06, Assad Jarrahian <jarraa at gmail.com> wrote:
>>>>>>>I pasted the complete output below. Thanks for your help.
>>>>>>>make -C lwgeom
>>>>>>>make[1]: Entering directory `/packages/postgis-1.1.0/lwgeom'
>>>>>>>cpp -P -traditional-cpp -DUSE_VERSION=81 lwpostgis.sql.in | sed -e
>>>>>>>'s:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1
>>>>>>>USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.1.0:g;s/@POSTGIS_BUILD_DATE@/2006-01-12
>>>>>>>16:30:40/g' | grep -v '^#' > ../lwpostgis.sql
>>>>>>>/usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
>>>>>>>../lwpostgis_upgrade.sql
>>>>>>>-o measures.o measures.c
>>>>>>>-o box2d.o box2d.c
>>>>>>>-o ptarray.o ptarray.c
>>>>>>>ptarray.c: In function 'ptarray_segmentize2d':
>>>>>>>ptarray.c:223: warning: dereferencing type-punned pointer will break
>>>>>>>strict-aliasing rules
>>>>>>>-o lwgeom_api.o lwgeom_api.c
>>>>>>>lwgeom_api.c: In function 'lwgeom_getpoint_inspected':
>>>>>>>lwgeom_api.c:974: warning: pointer targets in assignment differ in signedness
>>>>>>>lwgeom_api.c:981: warning: pointer targets in passing argument 1 of
>>>>>>>'lwpoint_deserialize' differ in signedness
>>>>>>>lwgeom_api.c: In function 'lwgeom_getpoly':
>>>>>>>lwgeom_api.c:1051: warning: pointer targets in assignment differ in signedness
>>>>>>>lwgeom_api.c:1057: warning: pointer targets in passing argument 1 of
>>>>>>>'lwpoly_deserialize' differ in signedness
>>>>>>>lwgeom_api.c: In function 'lwgeom_getpoly_inspected':
>>>>>>>lwgeom_api.c:1069: warning: pointer targets in assignment differ in signedness
>>>>>>>lwgeom_api.c:1076: warning: pointer targets in passing argument 1 of
>>>>>>>lwgeom_api.c: In function 'lwgeom_getsubgeometry':
>>>>>>>lwgeom_api.c:1097: warning: pointer targets in assignment differ in signedness
>>>>>>>lwgeom_api.c:1099: warning: pointer targets in return differ in signedness
>>>>>>>lwgeom_api.c: In function 'printPA':
>>>>>>>lwgeom_api.c:1636: warning: pointer targets in assignment differ in signedness
>>>>>>>lwgeom_api.c:1637: warning: pointer targets in assignment differ in signedness
>>>>>>>lwgeom_api.c: In function 'printBYTES':
>>>>>>>lwgeom_api.c:1674: warning: pointer targets in passing argument 2 of
>>>>>>>'deparse_hex' differ in signedness
>>>>>>>lwgeom_api.c: In function 'pglwgeom_from_ewkb':
>>>>>>>lwgeom_api.c:1775: warning: pointer targets in passing argument 2 of
>>>>>>>lwgeom_api.c: In function 'lwgeom_typeflags':
>>>>>>>lwgeom_api.c:2000: warning: pointer targets in return differ in signedness
>>>>>>>lwgeom_api.c: In function 'parse_lwgeom_wkt':
>>>>>>>lwgeom_api.c:2242: warning: pointer targets in passing argument 1 of
>>>>>>>'parse_lwg' differ in signedness
>>>>>>>lwgeom_api.c: In function 'box2df_to_box3d':
>>>>>>>lwgeom_api.c:220: warning: 'result.zmin' is used uninitialized in this function
>>>>>>>lwgeom_api.c:220: warning: 'result.zmax' is used uninitialized in this function
>>>>>>>lwgeom_api.c:220: warning: 'result.ymax' is used uninitialized in this function
>>>>>>>lwgeom_api.c:220: warning: 'result.xmax' is used uninitialized in this function
>>>>>>>lwgeom_api.c:220: warning: 'result.ymin' is used uninitialized in this function
>>>>>>>lwgeom_api.c:220: warning: 'result.xmin' is used uninitialized in this function
>>>>>>>-o lwgeom.o lwgeom.c
>>>>>>>lwgeom.c: In function 'lwgeom_to_ewkb':
>>>>>>>lwgeom.c:409: warning: pointer targets in return differ in signedness
>>>>>>>-o lwpoint.o lwpoint.c
>>>>>>>-o lwline.o lwline.c
>>>>>>>-o lwpoly.o lwpoly.c
>>>>>>>lwpoly.c: In function 'lwpoly_deserialize':
>>>>>>>lwpoly.c:80: warning: pointer targets in assignment differ in signedness
>>>>>>>lwpoly.c:90: warning: pointer targets in assignment differ in signedness
>>>>>>>lwpoly.c:105: warning: pointer targets in passing argument 1 of
>>>>>>>'get_int32' differ in signedness
>>>>>>>lwpoly.c:113: warning: pointer targets in passing argument 1 of
>>>>>>>'get_uint32' differ in signedness
>>>>>>>lwpoly.c:121: warning: pointer targets in passing argument 1 of
>>>>>>>lwpoly.c:124: warning: pointer targets in passing argument 1 of
>>>>>>>'pointArray_construct' differ in signedness
>>>>>>>-o lwmpoint.o lwmpoint.c
>>>>>>>-o lwmline.o lwmline.c
>>>>>>>-o lwmpoly.o lwmpoly.c
>>>>>>>-o lwcollection.o lwcollection.c
>>>>>>>-o wktunparse.o wktunparse.c
>>>>>>>-o lwgparse.o lwgparse.c
>>>>>>>-o wktparse.tab.o wktparse.tab.c
>>>>>>>wktparse.y: In function 'lwg_parse_yyparse':
>>>>>>>wktparse.y:43: warning: pointer targets in passing argument 1 of
>>>>>>>'alloc_wkb' differ in signedness
>>>>>>>-o lex.yy.o lex.yy.c
>>>>>>>lex.yy.c:3044: warning: 'yyunput' defined but not used
>>>>>>>-o vsprintf.o vsprintf.c
>>>>>>>lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
>>>>>>>lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
>>>>>>>lwgeom_pg.h:28: error: syntax error before 'getGeometryOID'
>>>>>>>lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
>>>>>>>'getGeometryOID'
>>>>>>>lwgeom_pg.h:28: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:35: error: syntax error before '*' token
>>>>>>>lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
>>>>>>>lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
>>>>>>>'box2df_to_box'
>>>>>>>lwgeom_pg.h:36: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:37: error: syntax error before 'BOX'
>>>>>>>lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
>>>>>>>lwgeom_pg.h:40: warning: type defaults to 'int' in declaration of 'BOX2D_same'
>>>>>>>lwgeom_pg.h:40: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:40: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
>>>>>>>lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_overlap'
>>>>>>>lwgeom_pg.h:41: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:41: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
>>>>>>>lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_overleft'
>>>>>>>lwgeom_pg.h:42: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:42: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
>>>>>>>lwgeom_pg.h:43: warning: type defaults to 'int' in declaration of 'BOX2D_left'
>>>>>>>lwgeom_pg.h:43: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:43: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:44: warning: type defaults to 'int' in declaration of 'BOX2D_right'
>>>>>>>lwgeom_pg.h:44: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:44: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
>>>>>>>lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_overright'
>>>>>>>lwgeom_pg.h:45: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:45: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
>>>>>>>lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_overbelow'
>>>>>>>lwgeom_pg.h:46: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:46: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
>>>>>>>lwgeom_pg.h:47: warning: type defaults to 'int' in declaration of 'BOX2D_below'
>>>>>>>lwgeom_pg.h:47: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:47: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
>>>>>>>lwgeom_pg.h:48: warning: type defaults to 'int' in declaration of 'BOX2D_above'
>>>>>>>lwgeom_pg.h:48: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:48: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
>>>>>>>lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_overabove'
>>>>>>>lwgeom_pg.h:49: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:49: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
>>>>>>>lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_contained'
>>>>>>>lwgeom_pg.h:50: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:50: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
>>>>>>>lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_contain'
>>>>>>>lwgeom_pg.h:51: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:51: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
>>>>>>>lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2D_intersects'
>>>>>>>lwgeom_pg.h:52: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:52: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:53: error: syntax error before 'BOX2D_union'
>>>>>>>lwgeom_pg.h:53: warning: type defaults to 'int' in declaration of 'BOX2D_union'
>>>>>>>lwgeom_pg.h:53: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:53: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:55: error: syntax error before 'LWGEOM_same'
>>>>>>>lwgeom_pg.h:55: warning: type defaults to 'int' in declaration of 'LWGEOM_same'
>>>>>>>lwgeom_pg.h:55: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:55: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:56: error: syntax error before 'BOX3D_construct'
>>>>>>>lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX3D_construct'
>>>>>>>lwgeom_pg.h:56: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:56: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:57: error: syntax error before 'BOX2DFLOAT4_ymin'
>>>>>>>lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
>>>>>>>'BOX2DFLOAT4_ymin'
>>>>>>>lwgeom_pg.h:57: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:57: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:59: error: syntax error before 'LWGEOM_force_2d'
>>>>>>>lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOM_force_2d'
>>>>>>>lwgeom_pg.h:59: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:59: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:60: error: syntax error before 'LWGEOM_force_3dm'
>>>>>>>lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOM_force_3dm'
>>>>>>>lwgeom_pg.h:60: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:60: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:61: error: syntax error before 'LWGEOM_force_3dz'
>>>>>>>lwgeom_pg.h:61: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOM_force_3dz'
>>>>>>>lwgeom_pg.h:61: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:61: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:62: error: syntax error before 'LWGEOM_force_4d'
>>>>>>>lwgeom_pg.h:62: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:63: error: syntax error before 'LWGEOM_force_collection'
>>>>>>>lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
>>>>>>>lwgeom_pg.h:63: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:63: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:64: error: syntax error before 'LWGEOM_force_multi'
>>>>>>>lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
>>>>>>>lwgeom_pg.h:64: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:64: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:66: error: syntax error before 'LWGEOMFromWKB'
>>>>>>>lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOMFromWKB'
>>>>>>>lwgeom_pg.h:66: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:66: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:67: error: syntax error before 'WKBFromLWGEOM'
>>>>>>>lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
>>>>>>>'WKBFromLWGEOM'
>>>>>>>lwgeom_pg.h:67: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:67: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
>>>>>>>lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOM_getBBOX'
>>>>>>>lwgeom_pg.h:69: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:69: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
>>>>>>>lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOM_addBBOX'
>>>>>>>lwgeom_pg.h:70: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:70: warning: data definition has no type or storage class
>>>>>>>lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
>>>>>>>lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
>>>>>>>'LWGEOM_dropBBOX'
>>>>>>>lwgeom_pg.h:71: warning: parameter names (without types) in function declaration
>>>>>>>lwgeom_pg.h:71: warning: data definition has no type or storage class
>>>>>>>liblwgeom.c: In function 'trim_trailing_zeros':
>>>>>>>liblwgeom.c:158: warning: implicit declaration of function 'strchr'
>>>>>>>liblwgeom.c:158: warning: incompatible implicit declaration of
>>>>>>>built-in function 'strchr'
>>>>>>>liblwgeom.c:163: warning: implicit declaration of function 'strlen'
>>>>>>>liblwgeom.c:163: warning: incompatible implicit declaration of
>>>>>>>built-in function 'strlen'
>>>>>>>make[1]: *** [liblwgeom.o] Error 1
>>>>>>>On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>>>>Please show some more lines - starting right before the *first*
>>>>>>>>warning during make - after a make clean.
>>>>>>>>--strk;
>>>>>>>>On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
>>>>>>>>>I am talking about the latest release 1.10
>>>>>>>>>Yes it seems that I can find postgres.h
>>>>>>>>>pg_config --includedir-server
>>>>>>>>>What should I do with it?
>>>>>>>>>thanks.
>>>>>>>>>-assad
>>>>>>>>>>You're talking about postgis version ?
>>>>>>>>>>Can you find postgres.h under `/usr/bin/pg_config --includedir-server` ?
>>>>>>>>>>--strk;
>>>>>>>>>>On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
>>>>>>>>>>>David and all,
>>>>>>>>>>>Thanks. I got everything installed, but when installing postgis I
>>>>>>>>>>>got errors (see below).
>>>>>>>>>>>The configure summary:
>>>>>>>>>>>SUMMARY
>>>>>>>>>>>HOST_OS: linux-gnu
>>>>>>>>>>> PGSQL: /usr/bin/pg_config
>>>>>>>>>>>  GEOS: /usr/local/bin/geos-config (with C-API)
>>>>>>>>>>>  PROJ: dir=/usr/local
>>>>>>>>>>> ICONV: 1
>>>>>>>>>>>PORTNAME: linux
>>>>>>>>>>> PREFIX: /usr
>>>>>>>>>>>EPREFIX: ${prefix}
>>>>>>>>>>>    DOC: /usr/share/doc/postgresql-doc-8.1
>>>>>>>>>>>   DATA: /usr/share/postgresql/8.1/postgresql/contrib
>>>>>>>>>>>    MAN: /usr/share/postgresql/8.1/man
>>>>>>>>>>>    BIN: /usr/lib/postgresql/8.1/bin
>>>>>>>>>>>    EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
>>>>>>>>>>>and the errors:
>>>>>>>>>>>'getGeometryOID'
>>>>>>>>>>>'box2df_to_box'
>>>>>>>>>>>'BOX2D_overlap'
>>>>>>>>>>>'BOX2D_overleft'
>>>>>>>>>>>lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
>>>>>>>>>>>'BOX2D_overright'
>>>>>>>>>>>'BOX2D_overbelow'
>>>>>>>>>>>'BOX2D_overabove'
>>>>>>>>>>>'BOX2D_contained'
>>>>>>>>>>>'BOX2D_contain'
>>>>>>>>>>>'LWGEOM_getBBOX'
>>>>>>>>>>>'LWGEOM_addBBOX'
>>>>>>>>>>>'LWGEOM_dropBBOX'
>>>>>>>>>>>make: *** [liblwgeom] Error 2
>>>>>>>>>>>On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
>>>>>>>>>>>>Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian ha scritto:
>>>>>>>>>>>>>hey david and all,
>>>>>>>>>>>>> thanks for replying.
>>>>>>>>>>>>>I tried the first step and it raised an exception
>>>>>>>>>>>>>sudo apt-get postgresql-dev
>>>>>>>>>>>>>E: Invalid operation postgresql-dev
>>>>>>>>>>>>You should add an "install" just like this:
>>>>>>>>>>>>sudo apt-get install postgresql-dev
>>>>>>>>>>>>Regards,
>>>>>>>>>>>>Stefano
>>>>>>>>>>>>Stefano Costa
>>>>>>>>>>>>http://www.iosa.it Software Open Source per l'Archeologia
>>>>>>>>>>>>Jabber: steko at jabber.linux.it
>>>>>>>>>>>>GnuPG Key ID 1024D/0xD0D30245
>>>>>>>>>>>>Linux Registered User #385969 counter.li.org
>>>>>>>>>>>>_______________________________________________
>>>>>>>>>>>>postgis-users mailing list
>>>>>>>>>>>>postgis-users at postgis.refractions.net
>>>>>>>>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>>>>>>/"\    ASCII Ribbon Campaign
>>>>>>>>>>\ /    Respect for low technology.
>>>>>>>>>>X     Keep e-mail messages readable by any computer system.
>>>>>>>>>>/ \    Keep it ASCII.
>>>>>>>>/ \    Keep it ASCII.
>>>>>/ \    Keep it ASCII.
