[postgis-users] Postgis error with mapserver
Paul Ramsey pramsey at refractions.net
Tue Jan 17 08:56:19 PST 2006
Change your data statement in your mapfile to:
DATA "geom from inun_riscalt"
That may not work.
If you loaded the table with a mixed case, drop it and load it again
with all lower case, I am not sure the Mapserver mappostgis.c can
handle mixed case table names.  In fact, looking at the SQL it is
generating, I am sure it cannot.
P.
On Jan 17, 2006, at 8:47 AM, joanvp wrote:
>  Hi!!
> I've tried to show a postgis layer with UMN Mapserver. I've
> installed last version of postgresql with postgis (8.1). I've
> imported a shapefile with FME.
> I've tried this layer with Quantum GIS and all works fine. The
> problem is with UMN Mapserver (v4.6). This is the error log
> Warning: [MapServer Error]: prepare_database(): Error executing
> POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor
> BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d
> (geom)),'NDR'),OID::text from public.Inun_RiscAlt WHERE geom &&
> setSRID('BOX3D(326607 4245586.875,627250 4471069.125)'::BOX3D,
> find_srid('','public.Inun_RiscAlt','geom') )'
> Postgresql reports the error as 'ERROR: relation "inun_riscalt"
> does not exist '
> More Help:
> Error with POSTGIS data variable. You specified '<check your .map
> file>'.
> Standard ways of specifiying are : < br>(1) 'geometry_colum n from
> geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column
> name> using SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using
> SRID=#' clauses in.
> For more help, please see http://postgis.refractions.net/
> documentation.php
> This is my mapfile
> LAYER
>   NAME inun_riscalt
>   TYPE POLYGON
>   STATUS On
> CONNECTION "user=xxx password=xxxx dbname=bdmapserver
> host=localhost port=5432"
> CONNECTIONTYPE postgis
> DATA "geom from Inun_RiscAlt"
>   CLASS
>     NAME "Inun_RiscAlt "
>     COLOR 182 131 78
>     OUTLINECOLOR 4 24 93
>   END
> END
> Any solution?
> Thank you in advanced
> Yahoo! Photos
> Ring in the New Year with Photo Calendars. Add photos, events,
> holidays, whatever.
> postgis-users mailing list
