[postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0. 9 to PostgreSQL 8.1 with PostGIS 1.0
Sears, Jeremy Jeremy.Sears at CCRS.NRCan.gc.ca
Fri Jan 20 07:15:30 PST 2006
>>The postgis_restore.pl could create the dump list and also the dump ascii
but then gives an error because it does not allow me to write down the
password at the next >>step.
I was having a simmilar problem. Each time I'd run postgis_restore.pl It
would promt for my password 3 time before bailing, indicating that the
password was incorrect. It was pointed out to me that this can be avoided by
setting the following environment variables, PGUSER and PGPASSWORD. I also
found it useful to specify PGHOST, PGPORT, and PGDATA as well. You can set
the env variable at the cmmd prompt like this:
>set PGUSER=username
or you can set the in controlpanel-->system-->advanced-->
hope that helps
Jeremy
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Mario
Servin
Sent: January 20, 2006 10:06 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0.9 to
Hi everybody,
I failed completely to restore my data from a PostgreSQL 8.0 with PostGIS
0.9 to PostgreSQL 8.1 with PostGIS 1.0. I have both versions of PosgreSQL
running in Windows. I follow instructions in PostGIS docs from the
PostgreSQL installation for upgrading. The postgis_restore.pl could create
the dump list and also the dump ascii but then gives an error because it
does not allow me to write down the password at the next step. As I know
something about Perl I tried to modify the script without success.
Additionally, I still have the results from the old shp2pgsql and so I tried
to insert the data form psql using \i mysqlinsertionscript.sql. Tables are
created ok, but geom columns results in meaningless characters where it is
supossed to be something like "POINT (- 66.046532 -21.951437)" for example.
Can anybody help me?.
Regards,
            Mario Servin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060120/b2eb0975/attachment.html>
