[postgis-users] re: shp2sql and UTF8 question on Windows
Randy George
rkgeorge at cadmaps.com
Mon Jan 23 12:33:10 PST 2006
I am using postgresql-8.1.2-1 with PostGIS 1.1.1 on a Windows 2003 OS
installed using the installer from http://www.webbased.co.uk/mca/
I have a database created with ENCODING = 'UTF8'
I am then using the shp2sql translator to create a table from a shp file
with a municipio named Manat¡
¡ = hex A1
When I attempt to load the resulting sql file into the table I get this
error:
psql:test.sql:15: ERROR: invalid UTF-8 byte sequence detected near byte
0xa1
CONTEXT: COPY county, line 1, column NAME: "Manatí"
ROLLBACK
When I try to use the –W parameter I get this message:
WARNING: the -W switch will have no effect. UTF8 disabled at compile time
Is there a way to get around this?
Thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060123/7a3f0329/attachment.html>
