[postgis-users] viewing a large postgis table with several columns
Kevin Neufeld
kneufeld at refractions.net
Tue Jan 24 07:57:33 PST 2006
It sounds like you have large geometries that results in long wkt
representations. Try wrapping your geometry column with a
summary(the_geom) function call - it does just that ... displays a
summary of the geometry, just for display purposes. You could also try
using the \x option that toggles expanded output and limit your query to
1. Further, to guarantee that you don't have invalid values in your
attributes, add a few constriants to your table columns, like NOT NULL,
or restrict the domain to a set of expected values.
Cheers,
Kevin
First Last wrote:
>i have a big postgis table with several columns and whenever i try to display the content of that table using a select statement in postgresql(psql) i get several blank pages, followed by several pages with only dashes as content, then the geometry. it will take several pressings of the space bar before i get to the geometry part even if i limit the number of columns and rows to display in the select statement. also there are but a few rows with blank values and no record with a value of "-" so i don't know if i'm getting garbage result.
>_____________________________________________________________
>Check out Atenista.Net (www.atenista.net)- new design, regular content and additional services!
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Kevin Neufeld,
Refractions Research Inc.,
Phone: (250) 383-3022
Fax: (250) 383-2140
