[postgis-users] rename tables
christian.michels at eifelgeist.com christian.michels at eifelgeist.com
Mon Jan 30 00:52:40 PST 2006
hi,
I import shp files into postgres and want to rename the imported table. The problem is that when I rename the table using "alter table foo rename to foo_1" the entry in the geometry_colums table still points to the foo table.
Is there any postgis function which handles the renaming of tables or do I have to take care of that by myself using a sql query ?
Thanx for any help
Chris
