[postgis-users] Longest axis of a polygon
Michael Fuhr mike at fuhr.org
Tue Jan 31 17:57:21 PST 2006
On Tue, Jan 31, 2006 at 05:01:13PM +1100, Christian Heine wrote:
> > I'm not familiar with solving this problem so maybe this isn't
> > correct or what you need, but could you look for the pair of points
> > on the polygon's (simplified) exterior ring or convex hull separated
> > by the most distance?  It would be easy to iterate through the
> > points in a function.
> Thanks for the suggestion!  I looked at convexhull() and this seems
> to be quite ok for my purposes -
> How do I loop over a set of points in PostGIS/SQL?
Here's a function that I've only minimally tested.  As I said, I'm
not familiar with solving this particular problem so corrections
or improvements are welcome.  One possible problem is that for
certain geometries the function might return a linestring that lies
entirely outside the geometry, except for the endpoints; a crescent
comes to mind.
CREATE FUNCTION longestaxis(geom geometry) RETURNS geometry AS $$
DECLARE
    hull    geometry := convexhull(geom);
    ering   geometry;
    len     double precision;
    maxlen  double precision := -1;
    maxi    integer;
    maxj    integer;
BEGIN
    IF geometrytype(hull) IN ('POINT', 'LINESTRING') THEN
        RETURN hull;
    END IF;
    ering := exteriorring(hull);
    FOR i IN 1 .. npoints(ering) - 2 LOOP
        FOR j IN i + 1 .. npoints(ering) - 1 LOOP
            len := distance(pointn(ering, i), pointn(ering, j));
            IF len > maxlen THEN
                maxlen := len;
                maxi := i;
                maxj := j;
            END IF;
        END LOOP;
    END LOOP;
    RETURN makeline(pointn(ering, maxi), pointn(ering, maxj));
END;
$$ LANGUAGE plpgsql IMMUTABLE STRICT;
Michael Fuhr
