[postgis-users] Tools Support Postgis
Barend Köbben
kobben at itc.nl
Tue Jan 31 23:48:55 PST 2006
Hi Ezequias,
I know about the pluginon the PostGIS site, but that is (as it says on the site) "This driver currently only works with JUMP 1.1 and PostgreSQL <= 7.4."... As I (And many others) are now using PostGreSQL 8 and higher, it's not of much use.
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Ezequias Rodrigues da Rocha
> Sent: 31 January 2006 20:22
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Tools Support Postgis
> The Plugin is on the PostGIS website (postgis.org) down right the
> homepage.
> There is another file I need to find out where it was posted.
> Barend Köbben escreveu:
> > So, where can I find that plugin. On the page
> (http://openjump.org/wiki/show/Plugins) it says "PostGIS
> database connector (read only)" but there is no link...?
> > Barend Köbben
> > [PS] for consideration of you and/or your colleagues:
> > ITC is searching a Professor of Geodata Management and Engineering
> > more details: http://www.itc.nl/about_itc/vacancies/2005_010.asp
> >> Sent: 31 January 2006 19:47
> >> It support Read only Postgis via PlugIn.
> >> Sincerely
> >> Ezequias
> >> Matthew Perry escreveu:
> >>> Ezequias,
> >>> Does OpenJUMP actually support postgis? Last time I checked the
> >>> postgis plugin only worked with JUMP 1.1 and older versions of
> >>> postgres.
> >>> matt
> >>> On 1/31/06, Ezequias Rodrigues da Rocha
> >> <ezequias at recife.pe.gov.br> wrote:
> >>>> I would like someone put the OpenJUMP url and name on the
> >> the wiki page
> >>>> precisely at:
> >> http://postgis.refractions.net/support/wiki/index.php?ToolsSup
> >> portPostgis
> >>>> Where JUMP and no Links
> >>>> Why not put [OpenJUMP | www.openjump.org] ?
> >>>> Sincerely
> >>>> http://ezequiasrocha.blogspot.com
> >>>> msn:ezequias at hotmail.com
> >>>> "the worst of democracies is still better than the best of
> >> dictatorship"
> >>>> _______________________________________________
> >>>> postgis-users mailing list
> >>>> postgis-users at postgis.refractions.net
> >>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>> Matt Perry
> >>> perrygeo at gmail.com
> >>> http://www.perrygeo.net
> >> dictatorship"
> dictatorship"
