[postgis-users] 1.1.3 compilation problem
Stefano B.
stefano.bonnin at comai.to
Mon Jul 3 00:09:29 PDT 2006
Hi, when I compile postgis 1.1.3 on my freebsd 5.3 os I get the following:
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... no
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... no
checking iconv.h presence... no
checking for iconv.h... no
checking build system type... i386-unknown-freebsd5.3
checking host system type... i386-unknown-freebsd5.3
checking for geos-config... /usr/local/bin/geos-config
checking for proj... /usr/local/bin/proj
checking for flex... /usr/bin/flex
checking for dllwrap... no
checking for dlltool... no
checking for bison... bison -y
checking for perl... /usr/bin/perl
checking for xsltproc... no
checking for pdfxmltex... no
checking for db2pdf... no
checking for jw... no
checking which template to use... freebsd
configure: creating ./config.status
config.status: creating Makefile.config
config.status: creating config.h
config.status: config.h is unchanged
SUMMARY
HOST_OS: freebsd5.3
PGSQL: /usr/local/pgsql8.1/bin/pg_config
GEOS: /usr/local/bin/geos-config (with C-API)
(ldflags: -L/usr/local/lib)
PROJ: prefix=/usr/local libdir=/usr/local/lib
ICONV: 0
PORTNAME: freebsd
PREFIX: /usr/local/pgsql8.1
EPREFIX: ${prefix}
DOC: /usr/local/pgsql8.1/doc/contrib
DATA: /usr/local/pgsql8.1/share/contrib
MAN: /usr/local/pgsql8.1/man
BIN: /usr/local/pgsql8.1/bin
EXT: /usr/local/pgsql8.1/lib (\$$libdir)
gmake -C lwgeom
gmake[1]: Entering directory `/usr/src/smit/postgis-1.1.3/lwgeom'
bison -y -vd -p lwg_parse_yy wktparse.y
wktparse.y:40.14: parse error, unexpected ":", expecting ";" or "|"
wktparse.y:58.20-32: $3 of `geometry' has no declared type
wktparse.y:61.6-19: $1 of `geometry' has no declared type
wktparse.y:145.17: parse error, unexpected ":", expecting ";" or "|"
wktparse.y:232.14-31: $1 of `geom_multilinestring' has no declared type
wktparse.y:232.14-34: $2 of `geom_multilinestring' has no declared type
wktparse.y:235.20-37: $1 of `geom_multilinestring' has no declared type
wktparse.y:235.20-40: $2 of `geom_multilinestring' has no declared type
wktparse.y:235.20-43: $3 of `geom_multilinestring' has no declared type
wktparse.y:238.26-43: $1 of `geom_multilinestring' has no declared type
wktparse.y:238.26-46: $2 of `geom_multilinestring' has no declared type
wktparse.y:238.26-49: $3 of `geom_multilinestring' has no declared type
wktparse.y:238.26-52: $4 of `geom_multilinestring' has no declared type
gmake[1]: *** [wktparse.tab.c] Error 1
gmake[1]: Leaving directory `/usr/src/smit/postgis-1.1.3/lwgeom'
gmake: *** [liblwgeom] Error 2
gmake -C lwgeom
I have compiled with:
./configure --with-pgsql=/usr/local/pgsql8.1/bin/pg_config --with-geos --with-proj
gmake
thanks in advance
Stefano
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060703/5fb0a4d1/attachment.html>
