[postgis-users] problem with pgsql2shp and special characters/umlaute
Tyler Mitchell
tylermitchell at shaw.ca
Tue Jul 4 06:43:01 PDT 2006
Hi there,
You should probably be using UNICODE (UTF8) encoding instead.
SQL_ASCII is too limiting.
Tyler
On 4-Jul-06, at 3:11 AM, gis at eifelgeist.com wrote:
> Hi,
> concerning special characters (like £, § ...) and umlaute (like ä,
> ü, ö) I encountered some serious problems which are described as
> follows:
> I dump an existing shapefile to PostgreSQL using shp2pgsql.exe and
> psql.exe. This process works fine...all special characters and
> umlaute are displayed correctly in database.
> After that the same data has been dumped from PostgreSQL to
> shapefile using pgsql2shp.exe unfortunately the encoding of special
> characters and umlaute does not work properly since special
> characters and umlaute does not remain the same. Examples are as
> follows:
> Savièse = Savièse
> Unterbäch = Unterbäch
> Grône = Grône
> Bürchen = Bürchen
> Has anyone any idea?
> I use PostgeSQL 8.1.3 with POSTGIS 1.0.4 and GEOS 2.1.4.
> The encoding of the database is SQL-ASCII.
> Is it the right encoding of database?
> Thanks a lot in advance for your help.
> Kathrin
> postgis-users mailing list
