[postgis-users] Amoeba Hulls
William Andersen wkandersen at gmail.com
Wed Jul 5 13:14:51 PDT 2006
Steve,
I think you are onto something.
There are exactly 101 points in each of the polygons in the (small) sample
set that I have.
When i get a little more time i'll plot these with 3.6 degree wedges and see
if anything jumps out at me.
My working theory is that there are a set of rules determining what happens
at each control point. In some cases it's pretty simple as we have enough
points to pick one that includes the 80% points but not the 20% points. In
other cases it seems to be extrapolated from the neighboring points using
some kind of fitted curve.
Will
On 7/5/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Paul,
> Would you not just connect the dots, like this.
> 1) determine the 80% points, say by distance or whatever
> 2) order the points by radial angle increasing and radius decreasing
> 3) use something like a window say plus/minus 1/2 degree and select the
> maximum radius in the window and add that point to the polygon
> 4) step 1/2 degree and repeat 3)
> 5) close the polygon
> You probably need to have some special handling if there is a sudden
> change in radius to make sure no points get clicked out of the polygon.
> Anyway I think this would be a good start to the algorithm.
> -Steve
> Paul Ramsey wrote:
> > Indeed, nice to see that everything can be strung together.  I am trying
> > to visualize what a "squishyhull" function would have to do to work
> > though :)  It's a not uncommon request... the calculated equivalent of
> > someone squinting and drawing a line around a group of points.
> > P
> > Mike Leahy wrote:
> >> Hey there,
> >> If you can determine the closest 80% of points by whatever criteria,
> >> wouldn't you be able to use the convexhull() function?  I just tried
> >> this, and it looks okay to me:
> >> testdb=# select astext(convexhull('MULTIPOINT((0 1),(0 0),(1 0),(1
> >> 1))'::geometry));
> >>              astext
> >>  POLYGON((0 0,0 1,1 1,1 0,0 0))
> >> (1 row)
> >> I did the same thing after creating a points table with the separate
> >> in individual records with the same overall coordinates in the
> >> multipoint example above, and it worked okay too:
> >> testdb=# select astext(convexhull(collect(p))) from testpoint;
> >>              astext
> >> (1 row)
> >> It wouldn't be too hard to modify this to work using where condition
> >> that filters out the records of interest...or maybe on a saved view.
> >> The only problem is that it wouldn't produce a nice curvy polygon
> >> outline like in the sample William provided.
> >> Regards,
> >> Mike
> >> Paul Ramsey wrote:
> >>> So my guess is that you use drive-time to segment your population of
> >>> customers relative to the store into the "nearest X%" and then draw a
> >>> "shape" around that cloud of points.  And drawing the shape is the
> >>> "fun" part.
> >>> William Andersen wrote:
> >>>> It appears to be the same as this functionality in Business Analyst
> http://www.esri.com/software/arcgis/extensions/businessanalyst/about/customer-market.html
> >>>> I thought this was done using some older version of Arcview, but i'm
> >>>> not very familiar with esri's offerings.
> >>>> Will
> >>>> On 7/5/06, *Paul Ramsey * <pramsey at refractions.net
> >>>> <mailto:pramsey at refractions.net>> wrote:
> >>>>     This wouldn't be in vanilla arcview, was it in Network Analyst?
> >>>> The top
> >>>>     80% of points by drive distance might yield this shape.  Finding
> >>>> the
> >>>>     points would be straightforward, and then the hull building
> >>>> would be the
> >>>>     hand-waving part.
> >>>>     P
> >>>>      > Paul, Steve,
> >>>>      > Thanks for the quick replies, unfortunately it's pretty hard
> >>>> to tell
> >>>>      > from those images if they match.
> >>>>      > I've done some more digging and it turns out that these
> >>>> shapes were
> >>>>      > created in Arcview 3.x. The notes I have say...
> >>>>      >  > This approach selects a number of the outliers and joins
> the
> >>>>     extreme
> >>>>      > points using elliptical arcs.
> >>>>      >  > The arcs are all created in a direction moving out from the
> >>>>     store.
> >>>>      > However, I dont see customer points at the discontinuities in
> >>>> the
> >>>>     hulls,
> >>>>      > so it appears that the "extreme points" are perhaps
> >>>> interpolated.
> >>>>      > Will
> >>>>      > On 7/5/06, *Paul Ramsey* < pramsey at refractions.net
> >>>>     <mailto:pramsey at refractions.net>>> wrote:
> >>>>      >     William,
> >>>>      >     It doesn't look like this is a standard algorithm, but
> more
> >>>>     likely a
> >>>>      >     particular empirical technique provided by the particular
> >>>>     software you
> >>>>      >     were using.  So substituting some other technique might
> >>>> yield a
> >>>>      >     different shape entirely... do any of the techniques
> >>>>     mentioned here
> http://www.geospatial-online.com/geospatialsolutions/article/articleDetail.jsp?id=1348
> >>>>      >     sound like what was done to your data?
> >>>>      >     Paul
> >>>>      >      > I'm fairly new to postgis, and working to automate a
> >>>> number of
> >>>>      >      > processes.
> >>>>      >      > We are trying to compute market area polygons that look
> >>>>     like the
> >>>>      >      > attached image. These were created by some older
> >>>> software.
> >>>>      >      > They are referred to as Amoeba Hulls, and they contain
> >>>> 80%
> >>>>     of a
> >>>>      >      > store's customers. However I can't find any solid
> >>>>     documentation that
> >>>>      >      > would allow me to reproduce them.
> >>>>      >      > Does anyone have any ideas how these shapes are
> >>>> created or an
> >>>>      >      > alternate name that I might be able to google?
> >>>>     Additionally, we may
> >>>>      >      > be in a position to finance the development of this
> >>>> feature.
> >>>>      >     _______________________________________________
> >>>>      >     postgis-users mailing list
> >>>>      >     postgis-users at postgis.refractions.net
> >>>>     <mailto:postgis-users at postgis.refractions.net>
> >>>>     <mailto:postgis-users at postgis.refractions.net>>
> >>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060705/fb073045/attachment.html>
