[postgis-users] Angle
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Thu Jul 6 07:09:44 PDT 2006
Arnaud Lesauvage escreveu:
> Ezequias Rodrigues da Rocha wrote:
>> Ok, now I need to get the start and and point of a linestring
>> feature. Could you tell me please ?
>> Regards
>> Ezequias
>>>> Hi list,
>>>> Could someone tell me how to get an angle of a linestring feature ?
>>>> Regards...
>>> The azimuth(geometry, geometry) function might be what you are
>>> looking for.
>>> Input geometries are points, so you might use
>>> Azimuth(StartPoint(geometry), EndPoint(geometry)) if geometry is a
>>> Linestring.
>>> http://postgis.refractions.net/docs/ch06.html#id2528534
> What do you think these "StartPoint" and "EndPoint" functions do ?
> Have you read the documentation at http://postgis.refractions.net/docs/ ?
> All you questions are answered there.
> PS : Please, reply below the quotes. Thanks !
> Arnaud
> postgis-users mailing list
Arnaud (great name. The name of my grandfather),
I tried like this but the result (as you can see now) is too below.
dbpotgis=# SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as
azimuth from mub where gid = 2900;
     azimuth
 2.17998093202836
(1 row)
dbpotgis=#
The real angle is 143,9 and the function only rerutns 2.17...
Could you tell me what I did wrong ?
Regards ...
