[postgis-users] Newbie questions on what geometry to use
snacktime
snacktime at gmail.com
Fri Jul 7 09:51:17 PDT 2006
Thanks Mark!! I had been looking for an example of how to do the math on
this.
Chris
On 7/5/06, mark thomas <javaguru at bellsouth.net> wrote:
> Chris,
> Don't forget that the spatial functions perform calculations in the units
> of the input geometries, so for example if you have a point geometry in
> decimal degrees and you call Buffer(the_geom, 1) it will buffer the input
> geometry by 1 decimal degree. You'll have to convert your input (miles) to
> the correct units (decimal degrees). To save you some time, here are the
> functions in PL/PGSQL:
> -- function to convert miles into decimal degrees
> create or replace function convertMilesToDecimalDegrees(numeric) returns numeric as $$
> begin
> -- $1 = radius in miles
> -- x = ($1 * 63360) = convert to meters (i.e. 63360 meters/mile)
> -- x = (x * 0.0254) = convert to inches (i.e. 0.0254 inches/meter)
> -- x = (x / 1852) = convert to nautical miles (i.e. 1852 meters/nautical mile)
> -- x = (x / 60) = convert to decimal degrees of latitude =
> -- (i.e. 1 nautical mile = 1 decimal minute; therefore nautical miles/60 = decimal degrees
> return (((($1 * 63360) * 0.0254) / 1852) / 60);
> end;
> $$ language plpgsql;
> --function to buffer a geometry by a radius whose value is specified in miles
> create or replace function getBufferedGeometry(geometry,numeric) returns geometry as $$
> declare g geometry;
> begin
> select Buffer($1,convertMilesToDecimalDegrees($2)) into g;
> return g;
> end;
> Hope this helps.
> Regards,
> Mark Thomas
> On Tue, 2006-07-04 at 12:00 -0700,
> Mark Thomas
> Senior Software Engineer
> Awarix Corporation
> mthomas at awarix.com
> http://www.awarix.com
> *"Commit to the Lord whatever you do, *
> * and your plans will succeed." - Proverbs 16:3*
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060707/1691e4da/attachment.html>
