[postgis-users] My crusade to get the real angle
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Mon Jul 10 06:33:37 PDT 2006
Thank you very much Guido,
I still want to make an if statement on psql command line.
Best regards...
Ezequias
Guido Lemoine escreveu:
> Just use a 'where' clause. This is basic SQL. Nothing to do with PostGIS.
> UPDATE TABLE MUB SET ANGLE = 90 – ANGLE
> WHERE ANGLE BETWEEN 0 AND 90
> (try lower case if this doesn't work).
> GL
> Ezequias Rodrigues da Rocha wrote:
>> Hi list,
>> I am still on my crusade to my real angle (not azimuth). Even with
>> the mapserver doesen't helping me with labels I am sill trying to
>> retrieve the real angle of a linestring.
>> As you should know I have the azimuth of a set of linestrings and
>> after a radians to degree conversion I noticed that the XY system is
>> quite different from the Azimuth system and I need to do some
>> conversions for each quadrant.
>> *So my question is:* How do I apply a if statement on
>> Postgis/Postgresql ? I know is is not a Postgis question but I think
>> you could help me.
>> I am trying to run this command line on psql:
>> select angulo from mub;
>> IF ANGLE >= 0 AND ANGLE <=90 THEN
>> END IF;
>> But it does not work. Any help will be welcomed.
>> Regards ...
>> http://ezequiasrocha.blogspot.com
>> msn:ezequias at hotmail.com
>> "the worst of democracies is still better than the best of dictatorship"
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
