[postgis-users] Select largest polygon of a multipolygon ?
Ing. Carlos Eucario
carlos.eucario at gmail.com
Tue Jul 11 07:10:28 PDT 2006
Yes,
select the_geom
from mgm2000
where area(the_geom) in
select max(area(the_geom))
from mgm2000
where mgm2000 is a polygon table..., and the_geom is the geometry column
-- see U
Carlos Eucario
2006/7/11, Arnaud Lesauvage <thewild at freesurf.fr>:
> Hi List !
> Is there a simple way to get the largest polygon (largest area) of
> a multipolygon geometry, just with an SQL query ?
> If not, I can write a simple perl function to do that, but if this
> function already existed that would be better.
> Thanks !
> Aranud
> postgis-users mailing list
Carlos Eucario
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060711/8fc9074f/attachment.html>
