[postgis-users] ERROR: Operation on two GEOMETRIES withdifferentSRIDs
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Fri Jul 14 06:51:00 PDT 2006
Something like this ?
*update mul.lotes set geometry = setsrid(geometry, 29185); *
where geometry is the geometry field of my geographic table. ;-)
It works for me but I do not know how to recreate the constraint I must
delete.
Can anyone help me :
CONSTRAINT enforce_srid_geometry CHECK (srid(geometry) = 29185)
Regards.
Ezequias
Mark Cave-Ayland escreveu:
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of Johan V
>> Sent: 14 July 2006 12:46
>> To: postgis-users at postgis.refractions.net
>> Subject: Re: [postgis-users] ERROR: Operation on two GEOMETRIES
>> withdifferentSRIDs
>> Hi Mark and others,
>> Yes the geometry created on the fly is -1, but this same sql statement
>> (with the on the fly created geometry) does work on another table with
>> SRID=103300, but not on this one.
>> I need this specific sql statement because it is a statement that is
>> issued by a software product that makes a WFS/WMS service (GIS Service
>> over the internet) of this table.
>> So do I have to change or check some thing in the table to be able to
>> use this kind of sql statement:
>> SELECT the_geom FROM table_x WHERE ((the_geom && 'POLYGON((...))')).
>> Greetz,
>> Johan.
> Hi Johan,
> Hmmm that makes it a bit more tricky. Unfortunately the SQL being issued is
> relying on the implicit cast in PostgreSQL rather than using
> GeomFromText()/setSRID() as documented and so its behaviour may change
> across PostgreSQL/PostGIS versions - if you do get a chance to update the
> SQL in your client software, I would highly recommend it.
> As for the symptoms you are seeing, I am slightly baffled - can you post the
> output of \d <table> for one of your tables that works and your new one that
> doesn't, the exact SELECT queries being executed on each table, and can you
> confirm that both tables are in the same database running the same version
> of PostGIS?
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060714/f12da7b6/attachment.html>
