[postgis-users] patch for release 1.1.3
Shoaib Burq
shoaib at nomad-labs.com
Tue Jul 18 07:11:53 PDT 2006
there are some obvious unfreed memory allocations, unused variables
and some duplicate code in the source. here's a patch against release
1.1.3 to fix them.
cheers
shoaib
diff -u'rNF^function' postgis-1.1.3/loader/dbfopen.c postgis-1.1.3-patched/loader/dbfopen.c
--- postgis-1.1.3/loader/dbfopen.c 2006-01-16 21:42:57.000000000 +1100
+++ postgis-1.1.3-patched/loader/dbfopen.c 2006-07-12 04:05:48.000000000 +1000
@@ -574,15 +574,21 @@
/* Create the file. */
fp = fopen( pszFullname, "wb" );
- if( fp == NULL )
+ if( fp == NULL ) {
+ free(pszFullname);
return( NULL );
fputc( 0, fp );
fclose( fp );
fp = fopen( pszFullname, "rb+" );
if( fp == NULL )
+ free(pszBasename);
return( NULL );
free( pszFullname );
diff -u'rNF^function' postgis-1.1.3/loader/shpopen.c postgis-1.1.3-patched/loader/shpopen.c
--- postgis-1.1.3/loader/shpopen.c 2003-12-02 07:52:00.000000000 +1100
+++ postgis-1.1.3-patched/loader/shpopen.c 2006-07-12 04:04:34.000000000 +1000
@@ -673,12 +673,21 @@
sprintf( pszFullname, "%s.shp", pszBasename );
fpSHP = fopen(pszFullname, "wb" );
if( fpSHP == NULL )
- return( NULL );
+ return( NULL );
sprintf( pszFullname, "%s.shx", pszBasename );
fpSHX = fopen(pszFullname, "wb" );
if( fpSHX == NULL )
- return( NULL );
+ free( pszFullname );
+ free( pszBasename );
+ fclose( fpSHP );
+ return( NULL );
diff -u'rNF^function' postgis-1.1.3/lwgeom/liblwgeom.c postgis-1.1.3-patched/lwgeom/liblwgeom.c
--- postgis-1.1.3/lwgeom/liblwgeom.c 2006-04-18 20:28:48.000000000 +1000
+++ postgis-1.1.3-patched/lwgeom/liblwgeom.c 2006-07-12 03:29:32.000000000 +1000
@@ -79,6 +79,7 @@
if (!vasprintf (&msg, fmt, ap))
va_end (ap);
+ free(msg);
return;
printf("%s\n", msg);
@@ -101,6 +102,7 @@
va_end (ap);
+ free(msg);
return;
fprintf(stderr, "%s\n", msg);
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_api.c postgis-1.1.3-patched/lwgeom/lwgeom_api.c
--- postgis-1.1.3/lwgeom/lwgeom_api.c 2006-03-13 04:20:08.000000000 +1100
+++ postgis-1.1.3-patched/lwgeom/lwgeom_api.c 2006-07-12 03:55:44.000000000 +1000
@@ -1338,8 +1338,6 @@
type = MULTIPOINTTYPE;
if (type == LINETYPE)
type = MULTILINETYPE;
- if (type == POINTTYPE)
- type = MULTIPOINTTYPE;
if (finalType == COLLECTIONTYPE)
type = COLLECTIONTYPE;
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_chip.c postgis-1.1.3-patched/lwgeom/lwgeom_chip.c
--- postgis-1.1.3/lwgeom/lwgeom_chip.c 2006-06-03 02:59:51.000000000 +1000
+++ postgis-1.1.3-patched/lwgeom/lwgeom_chip.c 2006-07-12 03:06:53.000000000 +1000
@@ -1070,9 +1070,6 @@
/* allocate a slot for a tuple with this tupdesc */
slot = TupleDescGetSlot(tupdesc);
- /* allocate a slot for a tuple with this tupdesc */
- slot = TupleDescGetSlot(tupdesc);
/* assign slot to function context */
funcctx->slot = slot;
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_estimate.c postgis-1.1.3-patched/lwgeom/lwgeom_estimate.c
--- postgis-1.1.3/lwgeom/lwgeom_estimate.c 2006-05-30 18:38:58.000000000 +1000
+++ postgis-1.1.3-patched/lwgeom/lwgeom_estimate.c 2006-07-12 03:28:00.000000000 +1000
@@ -390,6 +390,7 @@
if (SPIcode != SPI_OK_CONNECT)
elog(ERROR,"build_histogram2d: couldnt open a connection to SPI");
+ free(result);
PG_RETURN_NULL() ;
@@ -401,6 +402,7 @@
if (SPIplan == NULL)
elog(ERROR,"build_histogram2d: couldnt create query plan via SPI");
+ free(result);
PG_RETURN_NULL() ;
@@ -412,6 +414,8 @@
if (SPIportal == NULL)
elog(ERROR,"build_histogram2d: couldn't create cursor via SPI");
+ free(result);
PG_RETURN_NULL() ;
@@ -539,7 +543,9 @@
if (SPIcode != SPI_OK_FINISH )
elog(ERROR,"build_histogram2d: couldnt disconnect from SPI");
- PG_RETURN_NULL() ;
+ free(result);
+ PG_RETURN_NULL();
#if DEBUG_GEOMETRY_STATS
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_functions_basic.c postgis-1.1.3-patched/lwgeom/lwgeom_functions_basic.c
--- postgis-1.1.3/lwgeom/lwgeom_functions_basic.c 2006-06-26 10:41:24.000000000 +1000
+++ postgis-1.1.3-patched/lwgeom/lwgeom_functions_basic.c 2006-07-12 04:07:08.000000000 +1000
@@ -554,10 +554,7 @@
poly = lwpoly_deserialize(serialized);
TYPE_SETZM(newpts.dims, 0, 0);
- newpts.npoints = 0;
- newpts.serialized_pointlist = lwalloc(1);
nrings = lwalloc(sizeof(POINTARRAY *)*poly->nrings);
- loc = newpts.serialized_pointlist;
for (j=0; j<poly->nrings; j++)
POINTARRAY *ring = poly->rings[j];
@@ -756,10 +753,7 @@
TYPE_SETZM(newpts.dims, 1, 0);
@@ -934,10 +928,7 @@
TYPE_SETZM(newpts.dims, 0, 1);
@@ -1136,10 +1127,7 @@
TYPE_SETZM(newpts.dims, 1, 1);
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_geos_c.c postgis-1.1.3-patched/lwgeom/lwgeom_geos_c.c
--- postgis-1.1.3/lwgeom/lwgeom_geos_c.c 2006-06-26 10:56:26.000000000 +1000
+++ postgis-1.1.3-patched/lwgeom/lwgeom_geos_c.c 2006-07-12 03:18:26.000000000 +1000
@@ -2540,7 +2540,11 @@
sq = ptarray_to_GEOSCoordSeq(lwpoly->rings[i]);
geoms[i-1] = GEOSGeom_createLinearRing(sq);
- if ( ! geoms[i-1] ) return NULL;
+ if ( ! geoms[i-1] )
+ free(geoms);
+ return NULL;
/*lwerror("LWGEOM2GEOS: exception during polygon hole conversion"); */
g = GEOSGeom_createPolygon(shell, geoms, ngeoms);
@@ -2567,7 +2571,11 @@
for (i=0; i<ngeoms; ++i)
geoms[i] = LWGEOM2GEOS(lwc->geoms[i]);
- if ( ! geoms[i] ) return NULL;
+ if ( ! geoms[i] )
+ free(geoms);
+ return NULL;
g = GEOSGeom_createCollection(geostype, geoms, ngeoms);
if ( ! g ) return NULL;
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_ogc.c postgis-1.1.3-patched/lwgeom/lwgeom_ogc.c
--- postgis-1.1.3/lwgeom/lwgeom_ogc.c 2005-12-31 04:40:37.000000000 +1100
+++ postgis-1.1.3-patched/lwgeom/lwgeom_ogc.c 2006-07-12 03:49:41.000000000 +1000
@@ -188,6 +188,7 @@
if ( subgeom == NULL )
elog(ERROR, "What ? lwgeom_getsubgeometry_inspected returned NULL??");
+ return -1;
type = lwgeom_getType(subgeom[0]);
diff -u'rNF^function' postgis-1.1.3/lwgeom/lwgeom_pg.c postgis-1.1.3-patched/lwgeom/lwgeom_pg.c
--- postgis-1.1.3/lwgeom/lwgeom_pg.c 2006-06-01 17:07:21.000000000 +1000
+++ postgis-1.1.3-patched/lwgeom/lwgeom_pg.c 2006-07-12 03:21:04.000000000 +1000
@@ -91,6 +91,7 @@
va_end (ap);
+ free(msg);
return;
elog(NOTICE, "%s", msg);
