[postgis-users] PostGIS kills all connections to the PostgreSQLserver
Michael de Armas (Micotan)
michael.dearmas at micotan.com
Thu Jul 20 07:47:46 PDT 2006
Thanks for your solution. However, I believe the Buffer algorithm should be
improved to avoid this work around that only would complicate an automation
process and is still taking a while.
I don't think there's any quality problem with the shape file, the boundary
is not simple because is following a river. If there was such a quality
problem, how would I explain that ArcGIS does the same buffer (on that very
shape) in 2 seconds maximum, and they are even rendering.
Bruce Rindahl wrote:
> My guess as to why this is happening is the shapefile is really poor
> quality
> with intersections (interior loops etc.) Where did you get it? ESRI maps
> and data CD?
> The fix is to do multiple buffers. I tested your query and it ran in 234
> seconds (20000 buffer).
> I then ran:
> SELECT area(buffer(buffer(buffer(transform(GeomFromText('POLYGON((....
> ......))', 4267), 32039), 1000), 9000), 10000);
> and got the same result in 25 seconds. I think the first buffer in effect
> cleans out the weird parts of the shape and then the rest are acting on a
> cleaner shape. A 60,000 buffer was done in 26 seconds.
> Hope an order of magnitude helps!
> Bruce Rindahl
