[postgis-users] Any improvements in GeomUnion speed ?
Robert Burgholzer
rburghol at chesapeakebay.net
Fri Jul 21 09:23:41 PDT 2006
Dylan,
You may try "MemGeomUnion". I work with extremely complicated shapes
such as soil maps myself, and they can be a bear. What I think I have
determined, is that these multi-polygons have many, many sub-polygons
and that is where GEOS starts to experience its difficulties. You may
wish to try as an experiment, geomUnion'ing (or memGeomUnion'ing) a
sub-set of your shapes, perhaps trying it for a single soil order first,
and see if that speeds up. Alternatively, you may do a simplify, but as
you may know, loss in shape edge resolution generally results from
simplify and this may be intolerable for your application. Also, if you
are trying to get a table with a multipolygon in there, you need to
encase your geomUnion within the "Multi()" function, as so:
update seggroups set the_geom = multi(memgeomunion(a.the_geom)) from
lrsegs_dd as a
Good luck, and post any succsess you may have to the list, as for my own
purposes I am still a bit clueless.
Robert
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Dylan Beaudette
Sent: Wednesday, July 19, 2006 8:27 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Any improvements in GeomUnion speed ?
Greetings,
I have just started using PostGIS and am very impressed thus far. Today
I
attempted some basic GIS geometry operations, namely the GeomUnion
function.
Some background:
Software:
postgresql-8.1.2
geos-2.2.1
postgis-1.1.1
Geometry in question is about 4,000 rather detailed polygons:
Table "public.ca_soil_order_poly"
Column | Type | Modifiers
wkb_geometry | geometry | not null
soil_order | character varying(255) |
Indexes:
"ca_soil_order_poly_spatial_idx" gist (wkb_geometry) CLUSTER
"soil_order_ca_soil_order" btree (soil_order)
An example of the query used was:
create table ca_soil_order_poly_dissolved as select
GeomUnion(wkb_geometry)
as wkb_geometry, ca_soil_order_poly.soil_order
from ca_soil_order_poly
group by ca_soil_order_poly.soil_order ;
...this query ran for over an hour, without returning results. I have
noticed
quite a few past messages on the list about the performance penalties
imposed
by moving features to and from GEOS.
Just to make sure that I was doing everything that I could possibly do
to
speed up this operation I did:
--make some indexes
CREATE INDEX soil_order_ca_soil_order on ca_soil_order_poly (soil_order)
CREATE INDEX ca_soil_order_poly_spatial_idx on ca_soil_order_poly using
gist
(wkb_geometry gist_geometry_ops);
-- hint for speeding up Union operations
ALTER TABLE ca_soil_order_poly ALTER COLUMN wkb_geometry SET not null;
CLUSTER ca_soil_order_poly_spatial_idx on ca_soil_order_poly;
VACUUM ANALYSE ca_soil_order_poly ;
however, the resulting query plan didn't look to hopeful...
QUERY PLAN
HashAggregate (cost=372.67..372.78 rows=9 width=4704)
-> Seq Scan on ca_soil_order_poly (cost=0.00..352.11 rows=4111
width=4704)
After reading the mailing list archives, I was unable to glean any
further
ideas on how to make this type of operation go faster. I suppose that if
all
else fails, I can do this operation in GRASS.
Thanks in advance !
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
