[postgis-users] Inserting geometries using a JDBC PreparedStatement
Guido Lemoine
guido.lemoine at jrc.it
Tue Jul 25 00:28:31 PDT 2006
Corey,
Apparently, you do no longer need the single quote around the LINESTRING.
I reproduced your problem and found that dropping the single quotes
solves the
problem. I am using 8.0.3/1.0. Curious.
GL
Corey Puffalt wrote:
> All...
> Has anyone been able to insert geometries using a standard JDBC
> PreparedStatement successfully with Postgis 1.1.3 & Postgresql 8.1.4?
> I had this working with postgis 0.8 & Postgresql 7.4.1 but I'm now
> upgrading to the latest versions.
> Here's what I'm attempting to do (stripped down for simplicity...error
> handling removed etc.):
> ==========>8==========
> String psqlInsertLine =
> "INSERT INTO gis_table (id, attr1, geometry, attr2) " +
> "VALUES (?, ?, GeometryFromText(?,4267), ?)";
> PreparedStatement insertStmt = conn.prepareStatement(psqlInsertLine);
> String geometry = getGeometry(attr1, attr2); // get a geometry based
> on the attributes...
> insertStmt.setString(1, id);
> insertStmt.setString(2, attr1);
> insertStmt.setString(3, geometry);
> insertStmt.setString(4, attr2);
> insertStmt.executeUpdate();
> ==========8<==========
> geometry is a string. For example:
> "'LINESTRING(-113.7568111 57.1167611 ,-113.7568111 57.1167611
> ,-113.8803611 57.1146194 ,-113.8803611 57.1146194 )'"
> This works under 0.8 but with 1.1.3 I'm getting the following error:
> org.postgresql.util.PSQLException: ERROR: Invalid OGC WKT (does not
> start with P,L,M or G)
> As you can see my WKT does, in fact, start with an L ?!?
> Does anyone how to get this working? What am I doing wrong?
> Thanks,
> Corey
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
