[postgis-users] Inserting geometries using a JDBC PreparedStatement
Yeroc
cplists at gmail.com
Tue Jul 25 08:08:40 PDT 2006
Markus,
I tried it with both the jdbc driver I had been using previously as well as
the new one bundled with v8.1.4. There was no difference in behavior
between the two drivers. The difference appears to be in the backend.
The code is identical. I took my existing code and just re-ran it against
the new database. As you say, now that I think about it, it's a wonder that
it ever worked. There must have been a bug (or feature? ;) in the backend
that caused it to work before.
Thanks for your reply.
Corey
View this message in context: http://www.nabble.com/Inserting-geometries-using-a-JDBC-PreparedStatement-tf1993730.html#a5487120
Sent from the PostGIS - User forum at Nabble.com.
