[postgis-users] Multiple instances of postgres.exe, Geoserver hangs
GPS Blaster gps.blaster at gmail.com
Mon Jul 31 01:06:16 PDT 2006
Hi!
We have a problem with Geoserver, PostGIS and MapBuilder.
Our map displays fine, but we noticed a lot of instances of postgres.exe in
the task manager, simultaneously, mapbuilder fails to refresh some layers,
let's say street layer, that were showing, 20 or 30 seconds later you pan
the map and then street layer are not anymore shown.
We're not sure what causes the problem.
Is Geoserver requesting too many connections? (we test it from only one
client and still dozens of postgres.exe instances)?
Is Postgres.exe refusing more connections as a result of the many instances?
Could it be a driver / connector problem?
Thanks !
View this message in context: http://www.nabble.com/Multiple-instances-of-postgres.exe%2C-Geoserver-hangs-tf2026138.html#a5571600
Sent from the PostGIS - User forum at Nabble.com.
