[postgis-users] Problems with Debian and Postgis
alex bodnaru alexbodn at 012.net.il
Fri Jun 9 02:22:34 PDT 2006
as postgis should integrate with a proper postgresql, it should, in my
view, install using the guidelines of the hosting system.
installing from source is probably not very wrong on sarge, but it
definitely is on etch and sid, which have tremendously improved
postgresql installations.
plus, packaging systems are usually part of the reason to choose a
distribution, especially debian.
but if you can't package and properly manage something, use it as you can!
alex
Didrik Pinte wrote:
> Le vendredi 09 juin 2006 à 10:38 +0200, TECHER David a écrit :
>>If it is the case...The last solution => to install everything from
>>source!
> From a debian point of view, that's heretical ;-)
> Didrik
> postgis-users mailing list
