[postgis-users] PL/PgSQL and PostGIS
CYW
cyw at dls.net
Fri Jun 9 23:30:19 PDT 2006
Hi there,
I am trying a PL/PgSQL script below, and getting the following error:
invalid input syntax for integer: "Point(111.000 999.22)"
Context: PL/pgSQL function "testxy" line # 12 at fecth
Any suggestions?
CREATE OR REPLACE FUNCTION testxy() RETURNS text AS $$
DECLARE
thisrow point_table%ROWTYPE;
rid integer DEFAULT 1;
msg text;
cur CURSOR(key integer) FOR SELECT AsText(geom) as geom
FROM point_table WHERE guid=rid ORDER BY measure ASC;
BEGIN
OPEN cur(rid);
FETCH cur INTO thisrow ;
CLOSE cur;
RETURN thisrow.geom;
END;
$$ LANGUAGE plpgsql;
Thanks in advance
_cyw_
