[postgis-users] Degrees to meters
Kevin martins martins506 at hotmail.com
Wed Jun 14 11:21:02 PDT 2006
Thanks fot your help but I've allready use that function but  it did not work,
try:
select AsText(transform(GeometryFromText('POINT(-7,39)', 4326),4803);
You'll see that it does't do the right convertion, it gives the units in degrees but i want it in meters.How can i do it?
Cheers,
Kevin Martins
_________________________________________________________________
Veja mais. Compartilhe mais. Experimente gratuitamente a versão beta do Windows Live Messenger
http://ideas.live.com/programpage.aspx?versionId=0eccd94b-eb48-497c-8e60-c6313f7ebb73
