[postgis-users] Degrees to meters
Barend Köbben
kobben at itc.nl
Wed Jun 14 13:57:04 PDT 2006
You still do not understand apparently: your coordinates are ALWAYS in lat/lon as long as you use the SRID 4803, because that is an SRID that is defined as being a reference system on a sphere (or ellipsoid), indicating places on the surface of the sphere as degrees from the centre of that globe (lat /long or lambda/phi). This is unlike a projected SRID using a Cartesian coordinate system: that is a projection of the spherical earth on a flat surface, , with the coordinates being X and Y (in meters of maybe feet or similar) from an origin.
As on of the first anwersers said: read a primer on map projections. A nice one is http://kartoweb.itc.nl/geometrics/
Good luck (and learning)!
Barend Köbben
International Institute for Geo-information Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31-(0)534874253; fax: +31-(0)534874335
From: postgis-users-bounces at postgis.refractions.net on behalf of Kevin martins
Sent: Wed 6/14/06 22:38
To: PostGIS Users Discussion
Subject: RE: Re: Re: Re: [postgis-users] Degrees to meters
Let me see if i did understand.
I have the coordinates from GPS (WGS-84) that is :
->lat: 39.8263083333 N
->long: -7.43232906 E
And I want to convert first this coordinates to meters into Lisbon datum(4803).
I know the coordinates of the Lisbon datum reference point is:
->lat: 39.6666667 N
->long: -8.0116667 E
What I want to do is know the coordinates, in meters, of the point, in the two datum (lisbon datum and WGS-84 datum).
I have to create a new datum and then use the transform function?How can I use ellipsoid? the origin is the lonlat of the lisbon datum reference (my map is using the lisbon datum)??
Regards.
Kevin
_________________________________________________________________
Veja mais. Compartilhe mais. Experimente gratuitamente a versão beta do Windows Live Messenger
http://ideas.live.com/programpage.aspx?versionId=0eccd94b-eb48-497c-8e60-c6313f7ebb73_______________________________________________
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060614/7edebb3a/attachment.bin>
