[postgis-users] Make test fails: lc-messages
Alastair Smith
alastair at outsidethecube.ca
Wed Jun 14 17:03:26 PDT 2006
When I run 'make test', I get the following error:
psql: FATAL: permission denied to set parameter "lc_messages"
I'm running Debian 3.1, PostgreSQL 7.4.6 and PostGIS 1.1.2.
If I run 'make install', everything seems to work fine (i.e. no errors).
However I can not run any of the *.sql files that come with PostGIS (same
error as above), and if I try adding GIS objects it says the function can't
be found.
I can supply more information, but I'm at a loss as to where to start.
Thanks,
Alastair
