[postgis-users] shp2pgsql bug?
strk at refractions.net strk at refractions.net
Fri Jun 16 02:51:03 PDT 2006
Which versions are you using of both  pgsql2shp and shp2pgsql ?
--strk;
On Fri, Jun 16, 2006 at 03:23:18PM +0930, Eric Lam wrote:
> Hello list,
> I am back porting geometries I have loaded in postgresql8.x with postgis
> 1.x to a postgresql 7.4.x with postgis 0.8.x
> I am doing a:
> pgsql2shp -f tmp.shp -g the_geom data MLSTable
> shp2pgsql -s 4283 -c -g the_geom -w tmp.shp MLSTable > table.sql
> All geometries are multilinestrings. However up until recently, I have
> only ever had 1 linestring in the multilinestring.
> For geometries with more than 1 linestring in the multilinestring there
> is a comma at the start of every extra linestring except the first.
> eg MULTILINESTRING( (12 34, 23 34, 14 51),(,25 43,34 23,34 54),(,76
> 45,34 23))
> Is this a known problem? Is there something I am missing?
> At the moment I have piped the file through sed to remove the extra
> comma before loading into the older database.
> This is loading fine, however ....
