[postgis-users] shp2pgsql bug?
Eric Lam
elam at lisasoft.com
Sun Jun 18 17:41:10 PDT 2006
Thanks, it is now working as expected for my data.
regards
Eric Lam
strk at refractions.net wrote:
>Never mind, I could reproduce the problem with current head
>and have fixed it. Can give CVS a try ?
>I added support for loader/dumper test, automatically run
>by 'make test'. Currently tests for MULTILINE in all dimensions
>are provided.
>--strk;
>On Fri, Jun 16, 2006 at 11:51:03AM +0200, strk at refractions.net wrote:
>>Which versions are you using of both pgsql2shp and shp2pgsql ?
>>--strk;
>>On Fri, Jun 16, 2006 at 03:23:18PM +0930, Eric Lam wrote:
>>>Hello list,
>>>I am back porting geometries I have loaded in postgresql8.x with postgis
>>>1.x to a postgresql 7.4.x with postgis 0.8.x
>>>I am doing a:
>>>pgsql2shp -f tmp.shp -g the_geom data MLSTable
>>>shp2pgsql -s 4283 -c -g the_geom -w tmp.shp MLSTable > table.sql
>>>All geometries are multilinestrings. However up until recently, I have
>>>only ever had 1 linestring in the multilinestring.
>>>For geometries with more than 1 linestring in the multilinestring there
>>>is a comma at the start of every extra linestring except the first.
>>>eg MULTILINESTRING( (12 34, 23 34, 14 51),(,25 43,34 23,34 54),(,76
>>>45,34 23))
>>>Is this a known problem? Is there something I am missing?
>>>At the moment I have piped the file through sed to remove the extra
>>>comma before loading into the older database.
>>>This is loading fine, however ....
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
