[postgis-users] oid field
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Tue Jun 20 09:47:40 PDT 2006
No,
The PostGIS driver on OpenJUMP does not takes care of it yet. My problem
is the Mapserver (a web server thar connects with a PostGIS database).
OpenJUMP can save and retrieve later, but mapserver needs this kind of
data to exibit a map on the web or on OpenJUMP.
Thank you
Ezequias
Aaron Koning escreveu:
> Version 8.1 doesn't create the oid field by default. I'm not sure how
> to generate a system oid field, but you can always do: ALTER TABLE xyz
> ADD COLUMN oid serial; I'm not sure if this fills in the oid value for
> each row, or whether you have to do that after the fact.
> oid is a sort of system field that, when created by default, isn't
> displayed with "\d". Not sure why.
> When using JUMP, does a unique id field get created? With shp2pgsql
> GID is created and thats good enough for unique identification of rows...
> Aaron
> On 6/20/06, *Ezequias Rodrigues da Rocha* <ezequias at recife.pe.gov.br
> <mailto:ezequias at recife.pe.gov.br>> wrote:
>     Aaron,
>     When you tell new versions you mean 8.1 ?
>     Another question, why this field does not appears in a "\d" command ?
>     and how to generate this field if my application does not
>     generated it ?
>     Regards
>     > 'oid' is a database generated field containing unique values
>     (one for
>     > each row). In previous versions of PostgreSQL it was created by
>     > default, however in newer versions it is not generated by
>     default. The
>     > shp2pgsql loader creates a 'gid' field that also contains unique
>     > values, therefore the need for oid is moot ( i.e. use gid
>     instead of oid).
>     > Aaron
>     > On 6/19/06, *Ezequias Rodrigues da Rocha* <
>     ezequias at recife.pe.gov.br <mailto:ezequias at recife.pe.gov.br>
>     <mailto:ezequias at recife.pe.gov.br>>> wrote:
>     >     Could someone tell me what oid field does ?
>     >     I am using JUMP to load data into PostGIS and it is not
>     generating
>     >     this
>     >     king of column.
>     >     I just think it is a problem is becouse didn't load the
>     >     spatial_ref_sys
>     >     table yet.
>     >     Sincerely
>     >     Ezequias
>     >     _______________________________________________
>     >     postgis-users mailing list
>     >     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     <mailto:postgis-users at postgis.refractions.net>>
>     >     http://postgis.refractions.net/mailman/listinfo/postgis-users
>     >     <http://postgis.refractions.net/mailman/listinfo/postgis-users>
>     > |  Aaron Koning
>     > |  Information Technologist
>     > |  Prince George, BC, Canada.
>     > |  http://datashare.gis.unbc.ca/fist/
>     > |  http://datashare.gis.unbc.ca/gctp-js/
>     http://ezequiasrocha.blogspot.com
>     msn:ezequias at hotmail.com <mailto:msn:ezequias at hotmail.com>
>     "the worst of democracies is still better than the best of
>     dictatorship"
> |  Aaron Koning
> <http://datashare.gis.unbc.ca/gctp-js/>
"the worst of democracies is still better than the best of dictatorship"
