[postgis-users] oid field
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Tue Jun 20 10:30:05 PDT 2006
Great Mark, thank you for this important information.
Regards
Ezequias
Mark Cave-Ayland escreveu:
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of Ezequias Rodrigues da Rocha
>> Sent: 20 June 2006 17:48
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] oid field
>> No,
>> The PostGIS driver on OpenJUMP does not takes care of it yet. My problem
>> is the Mapserver (a web server thar connects with a PostGIS database).
>> OpenJUMP can save and retrieve later, but mapserver needs this kind of
>> data to exibit a map on the web or on OpenJUMP.
>> Thank you
>> Ezequias
> Hi Ezequias,
> If you mean UMN Mapserver (http://mapserver.gis.umn.edu) then the OID column
> isn't required - it is just the default choice for the primary key. You can
> override it using with the "USING UNIQUE" clause in the DATA statement - see
> the Mapserver documentation for more information.
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
