[postgis-users] Querying map layer based on a view
Dave Stone D.Stone at ed.ac.uk
Wed Jun 28 03:54:57 PDT 2006
I'm seeking advice on how to set up a view in PostgreSQL so that a layer
based on it can be queried in MapServer by clicking the map.
I've got a spatial table S and a number of other non-spatial tables
which I want to join in the view, so that attributes from all of them
can be included in the result-set.
If I set up a layer based solely on S, then I use the syntax 'using
unique oid' and everything is fine. When S is joined to the other
tables, however, oid will not uniquely identify a result record.
Is it permissible to put 'using unique oid, key2' where key2 is the
primary key from a non-spatial table, and oid and key2 between them
uniquely identify a result record?
Cheers,
Dave
