[postgis-users] Querying map layer based on a view
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jun 28 05:58:19 PDT 2006
Dave Stone wrote:
> I'm seeking advice on how to set up a view in PostgreSQL so that a layer
> based on it can be queried in MapServer by clicking the map.
> I've got a spatial table S and a number of other non-spatial tables
> which I want to join in the view, so that attributes from all of them
> can be included in the result-set.
> If I set up a layer based solely on S, then I use the syntax 'using
> unique oid' and everything is fine. When S is joined to the other
> tables, however, oid will not uniquely identify a result record.
> Is it permissible to put 'using unique oid, key2' where key2 is the
> primary key from a non-spatial table, and oid and key2 between them
> uniquely identify a result record?
Why not add a unique column to the view then you can reference that in
"using unique mycol"
-Steve
