[postgis-users] TopologyException
Arnaud Lesauvage thewild at freesurf.fr
Thu Mar 2 07:44:01 PST 2006
Hi list !
The following error is raised :
TopologyException: no outgoing dirEdge found
(742602,5.08777e+006,5.08777e+006)
ERROR:  GEOS Intersection() threw an error!
when I try to run this statement :
SELECT DISTINCT(c1.handle) AS handle
FROM cells_temp AS c1
INNER JOIN cells_temp AS c2
ON (c1.cell_geometry && c2.cell_geometry AND c1.handle!=c2.handle
AND IsValid(c1.cell_geometry) AND IsValid(c2.cell_geometry)
AND Relate(c1.cell_geometry,c2.cell_geometry,'2********'))
WHERE Area(Intersection(c1.cell_geometry,c2.cell_geometry))>0.5
I wrote this query to get all the geometries that overlap with
another geometry from the table (i.e. the surface of the
intersection is greater than 0.5 square meters).
If I remove the Intersection(c1.cell_geometry,c2.cell_geometry),
the query runs fine !
IsValid returns true for the entire table !
Does anyone have a hint about what is going on ?
Thanks a lot !
Regards
Arnaud
