[postgis-users] postgis geometry sizes
Paul Ramsey
pramsey at refractions.net
Sun Mar 5 14:44:56 PST 2006
The 0.X geometries have a lot of overhead in them by their nature.
They store 3 ordinates even if you have 2D data. They have a pretty
big header, which can be a large proportion of object size for small
geometries (like points, or 2-vertex linestrings). As a result,
seeing a 100% fluff-up in data volume is not unexpected. For points
and small linestrings, 200% would be unsurprising. Plus, for simple
geometries, the spatial indexes themselves can be quite large, as the
bbox of a two-vertex linestring has as many ordinates as the original
shape (though a much smaller structure size due to a smaller
header). As a previous poster noted, if you have been doing
processing on the data in the table itself, you probably have a large
number of dead tuples. VACUUM FULL your table, then cluster it on an
index to reduce it to the minimum possible on-disk size. To reduce
your size even more, upgrade to the 1.X series, which have a much
less fluffy data structures (no unnecessary 3D overhead, smaller
headers, reduced precision indexes).
P
On 5-Mar-06, at 2:20 PM, Eric Lam wrote:
> I am using postgresql 7.4.5 and Postgis 0.8.2. The select
> postgis_full_version() did not work for me. But I know these were
> the versions built from source.
> On 3/6/06, Paul Ramsey <pramsey at refractions.net> wrote: What
> PostGIS version are you running ( select postgis_full_version() )?
> On 4-Mar-06, at 11:43 PM, Eric Lam wrote:
> > Hi List,
> > I have a set of data [multilinestrings]. The data is about 2gig. I
> > have processed the data and the data is now 11gig on disc, using
> > the realtion_size() command. I have counted the number of points
> > and the 11gig data set has 1/4 the number of points as the 2gig
> > data set. Does anyone know why this is? I am running short on disc
> > space.
> > Thanks
> > Eric Lam
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
