[postgis-users] Re: ogr2ogr error message for Tiger to PostgreSQL conversion
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 6 07:27:47 PST 2006
Timsy Bir wrote:
> Hi again,
> I wanted to update the error message from my last post. I tried the same
> command
> ogr2ogr -f "PostgreSQL" PG:dbname=mingle04 TGR08021.RT1
> on a clean database (new db with just postgis.sql and
> spatial_ref_sys.sql scripts run) and got a slightly different error message:
> ERROR 3: Failed to read record 500 of TGR08021.RT5
> ERROR 3: Failed to read record 2322 of TGR08021.RTS
> ERROR 3: Failed to read record 38 of TGR08021.RTC
> ERROR 3: Failed to read record 7088 of TGR08021.RTI
> ERROR 3: Failed to read record 0 of TGR08021.RTR
Timsy,
What version of GDAL/OGR are you using? Can you provide the tiger
county in question for me to do a test with?
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
