[postgis-users] installing postgis in Ubuntu 5.10(Breezy)
Mikael Schröder
miscx at spray.se
Tue Mar 7 11:06:04 PST 2006
That was a quick response!
I get the following message when I try to install
postgresql-8.1-postgis1: Could not select all packages for the
installation or upgrade. The following packages have unresolved
dependencies. .....
Depends: libgcc1 (>=1:4.0.2) but 1:4.0.1-4ubuntu9 will be installed
Depends: libgeos2c2a but it is not installable
Depends: libstdc++6 (>=4.0.2-4) but 4.0.1-4ubuntu9 will be installed
And after that just a "close"-button
So maybe my problem really is the lack of libgeos2c2a???
/Regards Mikael
On Mar 7, 2006, at 10:30 AM, Mikael Schröder wrote:
> Hi all!
> I followed this thread and read every thing I could find on the
> matter, but when I try to add the PostGIS 8.1 deb from within
> Synaptic in Breezy, Synaptic complains about wrong version of
> libstdc (4.0.1 instead of 4.0.2) and consequently libgeos2c2. How
> can I handle this problem without compiling from source or changing
> to next version of libstdc wich I understand to be a bit
> bothersome. Does anyone have a different pkg for breezy?
> /Mikael
> >I appreciate your help, but I think you are working in unstable
> with >libstdc++ 4.02 and I'm in Breezy with libstdc++4.01. If
> Blair can fix >his pkg then that gives Breezy users both postgresql
> 8.1 & postgis.
What issue are you seeing? The packages I built are only built
against Breezy's packages. I make all the packages I built available
in my site, so there shouldn't be any dependencies that are not
fullfilled.
Also, shouldn't 4.01 and 4.02 be binary compatible?
Regards,
Blair
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060307/2e103240/attachment.html>
