[postgis-users] How to see the constraints generated by PostGIS
Michael Fuhr mike at fuhr.org
Wed Mar 8 10:23:07 PST 2006
On Wed, Mar 08, 2006 at 02:52:45PM -0300, Ezequias Rodrigues da Rocha wrote:
> I need to see the constraints generated by postgis. I did some shp2pg
> and now I need to see how this constraints where defined.
In psql run "\d tablename"; if you're using some other client then
check its documentation.  Or query the system catalogs:
SELECT conname, contype, pg_get_constraintdef(oid, true)
FROM pg_constraint
WHERE conrelid = 'tablename'::regclass;
Michael Fuhr
