[postgis-users] Conference Workshop Data Set - Poly layers won'tload
Geo Lists
geolists at gmail.com
Mon Mar 13 08:11:16 PST 2006
Mark,
Thanks for the response. I will try it at the commandline. I had
started out loading the data using the psql commandline, but when I
ran into some errors, I went to pgAdmin to read the error messages
more easily. (error was due to UTF encode option...)
Also, I apologize for the email format. Personally, I don't like html
emails either. I am using a Gmail account that I don't use a lot and
didn't think to set the default to text.
Thanks again for your quick response.
David.
On 3/13/06, Mark Cave-Ayland <m.cave-ayland at webbased.co.uk> wrote:
> > From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Geo
> Lists
> > Sent: 12 March 2006 21:37
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Conference Workshop Data Set - Poly layers
> won'tload
> > I am playing around with the data from the Intro to PostGis workshop at
> MUM2005. (Great workshop by the way!)
> > I am running postgres 8.1.2 and PostGis 1.1.1. on Windows. I was able to
> load the
> > bc_pubs and bc_municipality, but bc_roads and bc_voting_areas.
> > I build the sql file with shp2pgsql and then try to run it in the SQL
> window of
> > PGAdminIII. The file loads (after a while) and the sql appears to excute,
> but no
> > messages are generated. No table is created either. These large shape
> files do appear > to tax the laptop resources, so the only thing that I can
> think of is that I am running > out of memory or something. Anyone have an
> idea or had a similar situation?
> > David.
> Hi David,
> Have you tried loading in the resulting SQL file from the command line using
> psql? I can't say that I've used pgAdmin III to load large datasets but I've
> used psql without any problems. I normally fire up a command prompt in the
> PostgreSQL directory and then do something like:
> psql.exe –d mydatabase –f mysql.sql –U pguser
> BTW a lot of people on this list don't use PostgreSQL/PGAdminIII on Windows
> and so will not be able easily read HTML emails – you're more likely to get
> a response if you post messages in plain text format.
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-users mailing list
