[postgis-users] PostGIS without JTS or GEOS
TECHER David
davidtecher at yahoo.fr
Wed Mar 15 05:36:10 PST 2006
I think U need to used Geos for what U are doing!
As Nico said, from PostGIS doc
PointOnSurface(geometry)
Return a Point guaranteed to lie on the surface
Implemented using GEOS
OGC SPEC 3.2.14.2 and 3.2.18.2 -
One solution I give is first trying to backup your database with only
the tables then
rebuild postgis with geos
So let's go:
Backup only for tables:
su 'postgres_usre_you_are'
export yourdatabase=????????;for i in $(psql -d ${yourdatabase} -AtF ""
-c "select tablename from pg_tables where (tablename not like 'pg_%')
and (tablename not like 'spatial_ref_sys' ) and (tablename not like
'sql_%' ) and (tablename not like 'geom%' ) order by tablename");do
pg_dump -civOt $i $yourdatabase >> ~/${yourdatabase}_dump.sql;done
replace ????? by then name of your database
cd /path/to/postgis-1.0.0/sources
make uninstall clean distclean
cd ..
wget http://geos.refractions.net/geos-2.2.1.tar.bz2
tar xjjf geos-2.2.1.tar.bz2
cd geos-2.2.1;./configure && make && make install
If your need to specify the gcc version U could try
CC=gcc-3.4 CXX=g++-3.4 ./configure
before make and make install
See if geos it installed by trying
geos-config --version
then
try
which geos-config
if u have something like '/usr/local/bin/geos-config'
do
cat /etc/ld.so.conf
then see if it send U something like '/usr/local/lib' or else
do echo /usr/local/lib >> /etc/ld.so.conf
then
ldconfig
./configure --enable-autoconf --with-geos=$(which geos-config)
N.B: Since 1.0.0 is not available on PostGIS I'm very sure for the
options above so try ./configure --help for the option for geos
make
make install
dropdb yourdatase
createdb yourdatabse and so on
then psql -d yoyrdatabase -f ~/"your_database"_dump.sql
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
