[postgis-users] pgsql2shp - Could not create dbf file
Fay Du
fay.du at versaterm.com
Mon Mar 20 07:41:53 PST 2006
Paul:
Thank you very much for the quick anawer. After I changed output file
dir, the problem is solved.
Fay
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, March 20, 2006 10:38 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] pgsql2shp - Could not create dbf file
Are you running it in a directory where you have write permissions?
On Mar 20, 2006, at 7:33 AM, Fay Du wrote:
> Hi everyone:
> I got an error when I use pgsal2shp.
> My server is Linux
> The command I used is: pgsql2shp -f newroads gisdb testarea
> Where, newroads is my out put file name, gisdb is database
> name, and testarea is table name.
> After hit enter button, I got the message: Initializing...
> What was wrong? Any help will be appreciated.
> Fay
> postgis-users mailing list
