[postgis-users] Problem with Contains/Within using shapes created by GeomUnion
strk at refractions.net
Mon Mar 20 10:32:30 PST 2006
There might be a bug in the computed bounding box of your geometries,
Try to run the within and contains against a dropbbox() version
of the input. If the problem persist, please provide a small
self-contained testacase so we can check against different
versions and architectures.
TIA
--strk;
On Fri, Mar 17, 2006 at 01:47:58PM -0500, Mike Leahy wrote:
> Hello list,
> I'm wondering if I've run into a bug with PostGIS (or maybe the GEOS
> module). I've been building a set of management areas that are created
> from a series of smaller districts merged together. I would normally
> expect the resulting merged polygon to topologically contain all of its
> constituent polygons. This has proved to be true in all cases for my
> data except one (so far). You can see the results of a test query below
> that compares a handful of shapes to their geomunion'd shape. In all
> cases except the shape with ID# 725, it looks fine. For some reason, a
> geomunion of that shape with the other contiguous shapes will no longer
> contain the original shape itself according to the contains() or
> within() functions. I've looked at this shape using Qgis and compared
> it to the corresponding geomunion shape, and it looks fine as far as I
> can tell visually.
> I've included a dump of a test table containing the six shapes in this
> management area used in the queries shown below. Let me know if there's
> anything I can do to work around this problem, or if there's any
> additional information I should provide.
> Mike
> testdb=# select gid, contains(u,the_geom), within(the_geom,u),
> isvalid(the_geom) as the_geom_isvalid, isvalid(u) as u_isvalid,
> contains(the_geom,the_geom) as the_geom_contains_itself from gutest
> cross join (select geomunion(the_geom) as u from gutest) as foo;
> gid | contains | within | the_geom_isvalid | u_isvalid |
> 508 | t | t | t | t | t
> 17 | t | t | t | t | t
> 741 | t | t | t | t | t
> 195 | t | t | t | t | t
> 725 | f | f | t | t | t
> 18 | t | t | t | t | t
> (6 rows)
> testdb=# select version();
> version
> PostgreSQL 8.1.3 on i386-redhat-linux-gnu, compiled by GCC
> i386-redhat-linux-gcc (GCC) 4.1.0 20060210 (Red Hat 4.1.0-0.24)
> (1 row)
> testdb=# select postgis_full_version();
> POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS
> (1 row)
> postgis-users mailing list
State-collected Geographic Data is public property !
Reject the INSPIRE directive.
Sign the petition: http://petition.publicgeodata.org
