[postgis-users] shp2pgsql options?
Paul Ramsey
pramsey at refractions.net
Mon Mar 20 12:56:20 PST 2006
Thom,
oids are *not* required by Mapserver. They are used for queries, in
the case where you have not defined a unique column with "using
unique" in your DATA statement. But you do have a unique id in your
table... gid is created by shp2pgsql as a unique primary key.
So load up things in 8.1 w/o oids. Since you are using shp2pgsql as
your loader, you are getting a unique primary key called 'gid'
defined for you by the tool. So you can use this as a data statement:
DATA "the_geom from geotable using unique gid"
P.
On Mar 20, 2006, at 12:20 PM, Thom DeCarlo wrote:
> Hello,
> I've been trying to load a set of shapefiles into a PostgreSQL 8.1.1 +
> PostGIS 1.1.0 database and having a bit of trouble with missing
> "oids". I've
> read that the current PostgreSQL doesn't create tables with OID by
> default,
> but they are required for use with MapServer. Due to that, my load
> process
> becomes:
> shp2pgsql -p -I -s <EPSG> shapefile.shp tablename
> >tablename_create.sql
> vi tablename_create.sql
> add "WITH OIDS" to the "CREATE TABLE" command
> psql -d database -f tablename_create.sql
> shp2pgsql -a -s <EPSG> shapefile.shp tablename | psql -d database
> That's a bit of a pain when dealing with hundreds of shapefiles. Is
> there an
> option for shp2pgsql (maybe "-O") that would tell it to create the
> tables
> with OIDS?
> Thanks,
> Thom
> Thom DeCarlo
> there was coffee.
> life would go on.
> william gibson, the winter market
> postgis-users mailing list
