[postgis-users] Problem with Contains/Within using shapes created by GeomUnion
strk at refractions.net
Tue Mar 21 08:29:49 PST 2006
Sorry, I didn't notice the attachment.
I gave a look at it now, and I confirm the bug.
Having tried against current JTS (1.7.1) I can say the same bug is there.
This is probably another example of binary predicates working at
virtually infinite precision vs. constructive functions (geomunion)
applying a precision model.
See this thread on geos-devel:
http://geos.refractions.net/pipermail/geos-devel/2006-March/001841.html
--strk;
On Mon, Mar 20, 2006 at 03:08:33PM -0500, Mike Leahy wrote:
> strk:
> I'm not fully sure what should put in a self-contained test case - but
> if you use load sample shapes table I sent in my previous message
> (gutest.sql.zip - attached again to this message), then you can run all
> of the queries I mentioned earlier. I also tried the dropbbox function
> (see below), which produces the same result. Let me know if there's
> anything more I can do here.
> Mike
> On my winxp machine:
> createdb -U postgres test
> psql -U postgres -f ../share/contrib/lwpostgis.sql test
> psql -U postgres -f ../share/contrib/spatial_ref_sys.sql test
> psql -U postgres -f <path_to>/gutest.sql test
> psql -U postgres test
> test=# select gid, contains(dropbbox(gu),dropbbox(the_geom)) from gutest
> cross join (select geomunion(dropbbox(the_geom)) as
> gu from gutest) as u;
> gid | contains
> 508 | t
> 17 | t
> 741 | t
> 195 | t
> 725 | f
> 18 | t
> (6 rows)
> test=# select version();
> version
> PostgreSQL 8.1.1 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
> 3.4.2 (mingw-special)
> (1 row)
> test=# select postgis_full_version();
> POSTGIS="1.1.1" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS
> (1 row)
> strk at refractions.net wrote:
> > There might be a bug in the computed bounding box of your geometries,
> > Try to run the within and contains against a dropbbox() version
> > of the input. If the problem persist, please provide a small
> > self-contained testacase so we can check against different
> > versions and architectures.
> > TIA
> > --strk;
> > On Fri, Mar 17, 2006 at 01:47:58PM -0500, Mike Leahy wrote:
> >> Hello list,
> >> I'm wondering if I've run into a bug with PostGIS (or maybe the GEOS
> >> module). I've been building a set of management areas that are created
> >> from a series of smaller districts merged together. I would normally
> >> expect the resulting merged polygon to topologically contain all of its
> >> constituent polygons. This has proved to be true in all cases for my
> >> data except one (so far). You can see the results of a test query below
> >> that compares a handful of shapes to their geomunion'd shape. In all
> >> cases except the shape with ID# 725, it looks fine. For some reason, a
> >> geomunion of that shape with the other contiguous shapes will no longer
> >> contain the original shape itself according to the contains() or
> >> within() functions. I've looked at this shape using Qgis and compared
> >> it to the corresponding geomunion shape, and it looks fine as far as I
> >> can tell visually.
> >> I've included a dump of a test table containing the six shapes in this
> >> management area used in the queries shown below. Let me know if there's
> >> anything I can do to work around this problem, or if there's any
> >> additional information I should provide.
> >> Mike
> >> testdb=# select gid, contains(u,the_geom), within(the_geom,u),
> >> isvalid(the_geom) as the_geom_isvalid, isvalid(u) as u_isvalid,
> >> contains(the_geom,the_geom) as the_geom_contains_itself from gutest
> >> cross join (select geomunion(the_geom) as u from gutest) as foo;
> >> gid | contains | within | the_geom_isvalid | u_isvalid |
> >> 508 | t | t | t | t | t
> >> 17 | t | t | t | t | t
> >> 741 | t | t | t | t | t
> >> 195 | t | t | t | t | t
> >> 725 | f | f | t | t | t
> >> 18 | t | t | t | t | t
> >> (6 rows)
> >> testdb=# select version();
> >> version
> >> PostgreSQL 8.1.3 on i386-redhat-linux-gnu, compiled by GCC
> >> i386-redhat-linux-gcc (GCC) 4.1.0 20060210 (Red Hat 4.1.0-0.24)
> >> (1 row)
> >> testdb=# select postgis_full_version();
> >> USE_STATS
> >> (1 row)
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
State-collected Geographic Data is public property !
Reject the INSPIRE directive.
Sign the petition: http://petition.publicgeodata.org
