[postgis-users] spatial functions in PostGIS connection
    Paul Ramsey
    pramsey at refractions.net
    Tue Mar 21 13:29:40 PST 2006
Tom,
Can be done, you just need to use a different syntax (this is in the
documentation somewhere... if you don't like where, maybe you can
move it somewhere you consider more obvious? or start a postgis/
mapserver howto on the cms?)
> DATA "the_geom from (select gid, the_geom from outbreaks where
> distance(wkb_geometry,'POINT(-122 45)') = 10) as subquery using
> unique gid using srid=4269"
Paul
On Mar 21, 2006, at 12:27 PM, Kralidis,Tom [Burlington] wrote:
> Hi,
> I have a point dataset in PostGIS which I display via OGC:WMS with no
> problems:
>   NAME "outbreaks"
>   CONNECTIONTYPE postgis
>   CONNECTION "user=postgres dbname=devgeodb2"
>   DATA "the_geom from outbreaks"
> ..is it possible to embed PostGIS functions in the LAYER/DATA
> statement
> like:
>   NAME "outbreaks"
>   DATA "the_geom from outbreaks where distance(wkb_geometry,'POINT
> (-122
> 45)') = 10"
> I tried this and got a ServiceException.  I also tried
> Thanks
> ..Tom
> postgis-users mailing list
