[postgis-users] problem with postgis + qgis
    Mark Cave-Ayland
    m.cave-ayland at webbased.co.uk
    Thu Mar 23 04:31:23 PST 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Moacir Netto
> Sent: 21 March 2006 20:20
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] problem with postgis + qgis
> Help me
> I am with problem in the access the information of the postgis using
> the qgis, when I use usero with access restriction I do not obtain to
> visualize the data.. ???
Hi Moacir,
Are you saying that the user you are using to connect to the database in
qgis with cannot access the spatial tables? In that case, you'll need to
look at the user permissions:
http://www.postgresql.org/docs/8.0/interactive/privileges.html
http://www.postgresql.org/docs/8.0/interactive/sql-grant.html
Unfortunately without any more information, such as error messages, we can't
be any more specific.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
